Your Best Source for Genuine Mazda Parts!
Page 12 of 15 FirstFirst ... 21011121314 ... LastLast
Results 166 to 180 of 219
Thread: SkyActiv TSBs (Technical Service Bulletins)
  1. #166
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,358
    Blog Entries
    8
    NB1 Navigation Updates (1000 NEW-11/2017) / Why Mazda moly oil? - Mazda TSBs / Mazda owners manuals / SkyActiv Oil Analysis Thread
    Current Vehicles:
    '15 CX-5 GT 2.5L w/tech package & i-ACTIV AWD - Liquid Silver Metallic (04/2014 build-07/2014 delivery) - 40K Miles
    '12 Lexus GX 460 Premium (Toyota Land Cruiser Prado Kakadu 150) Body-On-Frame/ Torsen with ATRAC AWD - 45K miles
    '07 Infiniti G35x w/tech (Nissan Skyline V36) / ATTESA E-TS AWD - 93K miles
    '00 Jeep Wrangler 4.0L TJ - 5 speed / NP231 PT Transfer Case - 117K miles
  2. #167
    Registrierte Benutzer Chris_Top_Her's Avatar
    Donated: $40
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    5,277
    Quote Originally Posted by Kedis82ZE8 View Post
    Rattle / Chatter Noise From Rear Differential 2013-2016 Mazda CX-5
    http://mazda.oemdtc.com/719/rattle-c...-cx-5#more-719
    By oemdtc On March 8, 2016In Repair TipsTagged 2013, 2014, 2015, 2016, Chatter, CX-5, Mazda, Noise, Rattle, Rear Differential
    2013-2016 CX-5 AWD RATTLE / CHATTER NOISE FROM REAR DIFFERENTIAL
    APPLICABLE MODEL(S)/VINS
    2013-2016 CX-5 AWD vehicles with VINs lower than JM3KE******725078 (produced before October 1, 2015)
    While driving at low speeds, some vehicles may exhibit a chattering / rattling type noise from the rear of the vehicle.
    The noise may be caused by a rear differential bearing failure.
    The following mass-production changes have been implemented to eliminate the noise.
    Description Starting VIN and Production Date
    1. The assembly process was improved. JM3KE******391989 (September 16, 2013)
    2. The shape of the coupling unit housing was changed. JM3KE******725078 (October 1, 2015)
  3. #168
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,358
    Blog Entries
    8
    A-Pillar Trim Distortion Poor Appearance – 2013-2016 Mazda CX-5
    http://mazda.oemdtc.com/873/a-pillar...016-mazda-cx-5
    2013-2016 CX-5 vehicles with VINs lower than JM3KE******730190 (produced before Oct. 15, 2015)
    Poor appearance of the passenger and/or driver side A-pillar trim.
    The lower portion of the trim may become distorted (as shown below) due to high temperatures.
    A-pillar trim
    To eliminate this concern, the shape of the body flange has been improved during mass-production to allow sufficient A-pillar clearance.
  4. #169
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,358
    Blog Entries
    8
    For those with MMS there appears to be a new module version for those with issues.
    http://mazda.oemdtc.com/886/mazda-mo...mazda#more-886
    If a customer has a vehicle communication related error on their APP, perform the following:
    Disconnect the battery or unplug the module for at least 10 seconds.
    Reconnect the battery, wait 60 seconds and then have the customer try the APP again.
    If the vehicle starts, order module 0000-8F-Z80A.
    NOTE: THERE IS A LIMITED SUPPLY OF THE MODULE AT THIS TIME, THEREFORE ONLY USE THIS PART FOR THIS SPECIFIC CONDITION.
    Due to the limited supply, make sure you were shipped the A level part and not the original part before installing the part.
    Install the module and program it per MMS programming instructions.
    Instruct the customer to update their account with the new module information, otherwise the MMS will not work from the APP.
  5. #170
    Registered Member CX5Dude's Avatar
    Mazda CX5 GX 6 Speed
    Join Date
    Dec 2012
    Location
    Ottawa, Ontario Canada
    Posts
    34
    Hi Everyone,
    I got a notification on my 2016 CX5 6 speed in late December for a re-flash due to unusual idle. I lost the letter and can't seem to find it above. Can someone direct me to it? I have my first service next weekend and want to have it in hand.
    Thanks
  6. #171
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,358
    Blog Entries
    8
    DTC C1001 For Forward Sensing Camera (FSC) – 2014-2016 Mazda
    Some vehicles may have DTC C1001:92 stored in memory. DTC C1001:92 sets as a past record for low visibility of the Forward Sensing Camera (FSC). It does not mean there is an actual FSC defect.
    In some cases the customer may have a concern with the Lane Departure Warning System (LDWS) and/or High Beam Control system (HBC).
  7. #172
    Registered Member
    2015 Mazda6 GT
    Join Date
    Mar 2017
    Location
    South San Francisco, CA
    Posts
    28
    Just picked up a 15 '6 GT this past weekend. Will be getting the door moulding recall done next Friday. They are being a PITA about the Bluetooth Module TSB. They won't order it, even with a Mazda Handsfree Support case #, unless they diagnose it as the issue. Hopefully all works out.
  8. #173
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,358
    Blog Entries
    8
  9. #174
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,358
    Blog Entries
    8
  10. #175
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,358
    Blog Entries
    8
  11. #176
    Registered Member stromdriver's Avatar
    Mazda CX-5 Touring w/bose-tech
    Join Date
    Mar 2012
    Location
    cny
    Posts
    603
    months ago i got a letter about the struts on hatch, said to wait for another letter to arrange replacement, haven't heard anything since and didn't find anything relative in search on this thread
  12. #177
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,358
    Blog Entries
    8
  13. #178
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,358
    Blog Entries
    8
    Quote Originally Posted by stromdriver View Post
    I think Mazda is still sourcing parts for recall.
  14. #179
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colorado
    Posts
    2,001
    That was what I saw when I looked up recalls just yesterday.
  15. #180
    Registered Member
    Holden Commodore SSV
    Join Date
    Sep 2012
    Location
    SoCal
    Posts
    7
    Anyone done TSB 09-008/15 after the new car warranty expires?
    My 2014 CX-5 has 73k on the ODO, is a CPO, but the dealer is saying it won't be covered under the CPO 1 year warranty.
Similar Threads
  1. CX-7 TSB (Technical Service Bulletins)
    By Shaz in forum Mazda CX-7
    Last Post: 07-29-2014, 04:24 PM
  2. Replies: 2
    Last Post: 01-04-2014, 10:22 AM
  3. Replies: 0
    Last Post: 03-28-2013, 08:25 AM
  4. Technical Service Bulletins
    By CXRabbit in forum Mazda CX-7
    Last Post: 12-26-2006, 04:05 PM
  5. Technical Service Bulletins
    By Jim Frye in forum Protege5
    Last Post: 01-17-2003, 02:29 AM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
