I am putting together an install for my CX-5 Sport. I am debating on whether to go with an amp or a subwoofer.
Currently have:
Kenwood Excelon DNX690HD (20W RMS/50W Peak)
Polk DXi-6500 Components front (FR 35-26K) 6.5" bass in door, 1" tweeter in dash
Polk DXi-650 Coax Rear door
So, should I amp these bad boys with a Kenwood Excelon XR400-4 75W RMS x 4 or
install a Kicker Hideaway (150W RMS FR 25-120)? Note: I already ruled out the Sound Ordnance subs because the FR (40Hz) is no better than the polk and only provide about half the power of the Kicker.
Both would be installed under front seat. I only have enough funds for one, so both is not an option. So hear are my considerations:
Amp - Pros: Small, doesn't block heat vents, probably provides cleaner/crisper sound, still have decent bottom end with DXi-6500 FR down to 35Hz
Cons: Bass in door could rattle, more complicated wiring configuration (e.g. more expensive install)
Sub - Pros: Lots of bottom end, easier to install wiring, still get decent sound our of speakers since I can set crossover in HU and reduce power output needed
Cons: bigger, blocks heat vents, may not have sufficient power to drive Polks
So, what would you do - remember I can only do one of the two options. Any other pros/cons I am missing here?
Thanks,
DrK
Currently have:
Thanks,
DrK
