I am new to this forum but thought I would seek some advice on my situation. I have a 2010 CX9 GT with almost 36k miles on it. A couple weeks back it started making knocking/grinding noise when accelerating around a left hand turn and the noise was steadily getting worse each day. After 2 trips to the dealer it was discovered that 2 rod bearings were bad and that the engine needs to be replaced. Also, the dealer is claiming that there was only 2 qts of oil in it when they got it and Mazda won't warranty it because of the low oil level.
I am baffled as to how there could only be 2 qts of oil in it when I checked the oil level several times once the sound started happening and of course periodically between oil changes otherwise. I always do my own oil changes at the recommended intervals between 5000 and 7500 miles with 5w20 Amsoil Signature series along with Amsoil oil filters. I follow the standard procedure of the engine being warm but shut off for a couple mins when checking the oil too. Every time I checked the oil there was oil up the sides of the dipstick well past the top dot and the oil covered the dipstick consistently starting just below the top dot. Out of all the cars I have owned this vehicle has always been the hardest to check the oil level and as such I have always removed the dipstick, wiped, and reinserted a couple times to get a better reading. Also, I have only ever added oil in between oil changes a couple times. This engine has never used oil more than .5 qt in between oil changes. So how the engine could use 3.5 qts of oil over 6000 miles is beyond me. Especially with no signs of oil leaking or burning oil. I know I put 5.5 qts of oil in last time when I changed the oil.
Any thoughts on the oil usage, discrepenancy between oil level when I checked vs what the dealer says, and how to get to Mazda to cover the repair?
At this point they are only willing to cover the labor which leaves me with a $3500 bill to replace the engine.
