Slammedslug
- 2002 Mazda Protege5
ok just bought a P5 about a week ago, the check engine light came on and the codes are P0507 and P0421
sounds like the p0421 code is a bad cat on bannk 1?
also the P0507 code is somehting about the IAC and idle being to high anyone have any idea on what to check? is it the IAC thats bad or do i just need to adjust my idle?
i also noticed while looking under the car that there is a hose hanging in the rear of the car, by the gas tank and rear sway bar, IT IS NOT A GAS LINE nothing is leaking out of it and i cant even see were its coming from, i dont see anything what so ever in the area that it would connect to, anyone have any idea on this?
also the ABS and Brake light are one, ABS works just fine, fuse is not blown and it doesnt look like any of the ABS lines are broken at all, i checked the brake resivor brake fluid is above the normal line, and the float in the resivor seems just fine.
Weird thing is that they will both go off and on completly randomly they stay on more than they go off, im lost here and no the ebrake is not pulled at all and i checked the ebrake connection under the consol and it all seems fine
any help would be greatly appricated!
