Page 54 of 60 FirstFirst ... 4445253545556 ... LastLast
Results 796 to 810 of 900
Thread: The CX-5 LED Lighting Thread
  1. #796
    Registered Member
    Mazda CX5 touring 2017
    Join Date
    Apr 2017
    Location
    Oregon
    Posts
    18
    2017 CX5 Touring - need help with getting access to the license plate lights. I checked the manual and it says just wedge under the lens and firmly lift them off. Now, perhaps it's just me, but I'm scared as hell I'm going to break these lenses off or snap the arms off them. Has anyone done this for the 2017 version yet and can you verify that you simply wedged something under it (what did you use) and popped it off. The 2016 and prior look a little different from the current one and I'm just not sure about snapping it off without breaking it. Looking for suggestions.
  2. #797
    Registered Member Pipemajor's Avatar
    2017 CX-5, GT AWD w/Premium Pkg Eternal Blue Mica
    Join Date
    May 2014
    Location
    Minnesota
    Posts
    360
    Getting ready to turn in my '15 GT so pulled the VLEDS Tritons out of the front/rear turn signals and rear tail/stop light housings to put the stock incandescents back in.
    At first I thought there was something wrong with the 1157NA bulb for the right parking/turn signal light. The VLEDs Triton unit was brighter in the dim parking light mode than the incandescent 1157 on it's bright flash mode. On flash, the Triton was very bright. Definitely no problem being seen on a bright sunny day. At night, you see the reflective road signs far ahead of you return the flashing.
    I don't see where the '17 CX-5 uses the 1157NA bulb so I may be offering this for sale. The other VLEDs I took out will be retrofitted into the '17 where appropriate. The next owner of my '15 will benefit from the VLEDS fogs and DRLs I left in.
  3. #798
    Registered Member
    2004 Honda Civic Coupe and 2000 Toyota Celica GT
    Join Date
    Aug 2013
    Location
    Tampa
    Posts
    24
    Vleds hasnt updates their site for the 2017s yet. Any guides on what to purchase through them to replace all internal lights?
    Sent from my LG-H918 using Tapatalk
  4. #799
    Registered Member
    2016.5 Touring w/Tech
    Join Date
    Jan 2017
    Location
    Los Angeles
    Posts
    302
    Same question, but also - since there are like a million often contradictory posts on this topic - any consensus on good LED replacement bulbs for the interior, primarily overhead/map lights? I'm more interested in good than cheap as I've read too many posts where someone says what a great deal the bulbs were but that they only lasted for six months. In my case, for a 2016.
  5. #800
    Registered Member stromdriver's Avatar
    Mazda CX-5 Touring w/bose-tech
    Join Date
    Mar 2012
    Location
    cny
    Posts
    603
    Quote Originally Posted by RDK006 View Post
    all mine from superbright leds are still burning bright after 5 years
  6. #801
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    6,103
    Arrow The CX-5 LED Lighting Thread
    Quote Originally Posted by nuclfusion View Post
    All interior lights in 2017 CX-5 are the same as 1st-gen's as Mazda didn't make any changes for those. So basically you need five 30/31mm Festoon LEDs for map/dome/cargo lights、two 29mm 2,800K "warm white" Festoon T6 fuse type LEDs for vanity mirror、and two 194/168 type LEDs for license plate. You can always pay more for name brand LEDs but they normally don't use the latest LED chips. I have cheap eBay LED kit installed for 17 months and so far so good. Not all eBay LED kits are the same. You've to check the specs and reputation!
  7. #802
    Registered Member
    2016 Mazda CX-5 Sport/ Meteor Gray
    Join Date
    May 2016
    Location
    North Carolina
    Posts
    23
    does anyone know where I can get a vanity lighting kit? I have the sport trim which didn't come with vanity lights but I'd like to add them
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  8. #803
    Registered Member
    16.5 CX-5 GT AWD w/Tech BRMica
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    1,213
    Quote Originally Posted by yrwei52 View Post
    Installed the same cheap eBay kit as you last week. Highly impressed so far. Great little addition...
  9. #804
    Join Date
    May 2014
    Location
    Minnesota
    Posts
    360
    These are the ones I ordered from VLEDS for the interior festoons. They gave you a choice between 5K and 6K color temperature bulbs. I chose 6K since I had a black interior. The 6K bulbs gave a pretty 'cold' feel to the lighting quality. If I were to do it again I'd probably go with the 5K. I did choose 6K for the rear license bulbs and was pretty happy with those. Ran everything for 35 months and not a single failure although VLEDS indicates the one I have linked are on closeout.
    The fade feature Mazda uses when the interior lights go out does cause the LEDs to dim then flicker before going out.
  10. #805
    Join Date
    May 2014
    Location
    Minnesota
    Posts
    360
    Anyone wonder about the 'tiny' backup lights on the 2017s? Fear not, they are LED and very bright.
  11. #806
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    6,103
    Quote Originally Posted by Pipemajor View Post
    Yep Mazda at least did an easy LED upgrade on backup lights for new CX-5. I wish they had done LED upgrade on more complicated turn signals!
  12. #807
    Registered Member
    '17 3 & CX-5
    Join Date
    May 2017
    Location
    Canada
    Posts
    257
    I did the unthinkable and ordered a bulk buy of inexpensive ones off ebay. Enough to do both the new CX-5 and replace the other cheap ones I currently have in my 3. Those ones were found in my spare parts bin and they were insta-swapped in (also bought from ebay for my last car and never put in). No issues with even the ones currently in my 3, but they're a little less powerful than the ones I've ordered for the new car.
    Oddly enough, interior LEDs were one of the first things my wife noticed lacking in the new one on the test drive (her previous car had factory interior LED lighting) and she specifically asked me to "fix" it for her LOL.
    Hard to turn down enough bulbs to do 2 cars for <$10. Just have to wait for them to arrive sometime between now and the next 2-4 ish weeks.
  13. #808
    Registered Member
    Mazda CX-5 Grand Touring
    Join Date
    Feb 2017
    Location
    Minnesota
    Posts
    35
    Quote Originally Posted by Reedman99 View Post
    The lens are easy to take off. insert a small flat scredriver into the *sides* of the lens. There is a small indent post there. Spread the back support a bit and they will pop off. The bulbs are harder to get out as it's difficult to grab the bulb and pull it.
    I did wedge the same small screwdirver in the middle of the bulb and they finally popped out. Thought I was gonna break the bulbs.
    i used 194 LED's from superbright. Oh and it's on a 2014.
  14. #809
    Registered Member
    2016.5 mazda cx-5 touring
    Join Date
    May 2017
    Location
    hemet,ca
    Posts
    36
    Love the new 5730 t10 leds. Mind you look how much lights hitting the ground. $10 better than the $20 phillips I installed on my 3
    Sent from my VS988 using Tapatalk
  15. #810
    Join Date
    May 2014
    Location
    Minnesota
    Posts
    360
    I too, had a go at getting the lenses for the license plate lights off. My '15 had a pliable translucent lens which would easily pop off. The '17 uses a rigid clear plastic lens which doesn't seem to budge when prying it with a flat bladed screwdriver without fear of cracking the lens. I've studied the drawing in the manual but it's little help. Can't easily see how those black plastic ears inside the slot engage the clear plastic. Shaped like a V.
    Someone smarter than me is going to have to figure it out.
    EDIT: Issue resolved. Please see this post
Similar Threads
  1. HID lighting help please
    By zackmac in forum Protege5
    Last Post: 12-25-2012, 09:10 PM
  2. Lighting ifo
    By plum in forum CX-5 Accessories & Appearance
    Last Post: 07-11-2012, 06:45 PM
  3. Lighting
    By DR8907 in forum Mazda How-To
    Last Post: 01-04-2006, 07:05 PM
  4. lighting...
    By Javo in forum Pics & Builds
    Last Post: 02-13-2005, 01:26 AM
  5. HID Lighting
    By Protege73 in forum Mazdaspeed Protege
    Last Post: 02-09-2005, 02:39 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
