BushWickz
2021 CX-5 Reserve
Anyone tried LASFIT LED bulbs for the turn signals? As I understand it there's no separate flasher unit that can be swapped out to prevent regular LED bulbs from causing hyperflashing turn signals. But the LASFIT bulbs are available with built-in resistors. Fairly pricy, but not bad if you're only using 4 of those bulbs.
Maybe there are other brands that have this also, but this is the first time I've seen one.
7440 7441 W21W WY21W CANBUS Anti Hyper Flash LED Turn Signal Lights Blinker Bulbs | Amber Yellow, 2 Bulbs
Build in CANBUS will prevent 95% hyper flash and error warning. No need to mess around with resistors or cutting your car harness. The unique intelligent temperature control system ensures a longer lifespan.www.lasfit.com
I remember buying these pair of (BAU15S PY21W 12496 CANBUS Error Free Anti Hyper Flash LED Turn Signal Lights | Amber Yellow, 2) bulbs for my 20 Accord. They say they're Hyper Flash but after 20 mins or so they get too hot then start hyperflashing. I don't know if that version in specific do hyperflash but you could try. I believe they accept returns.
