Your Best Source for Genuine Mazda Parts!
Page 1 of 59 1231151 ... LastLast
Results 1 to 15 of 882
Thread: The CX-5 LED Lighting Thread
  1. #1
    Wheels, not rims... SayNoToPistons's Avatar
    CX-5 GT AWD w/ Tech, RX-8 GT 6spd w/ 'goodies'
    Join Date
    Dec 2008
    Location
    NYC/San Diego
    Posts
    1,782
    I figured I'd start a thread to collect all LED info since there are a few different threads with pages to dig through and not so thorough information.
    I am going to use VLED's website as reference to what bulbs fit. Of course I have no association with them. Only using them as they have a very nice collection and very informative on their products.
    Exterior:
    DRL FOR TECH PACK ONLY: P13W size bulbs. A somewhat rare bulb size. There are only a few different types of these LED's with different SMD (surface mount diode) arrangements and CREE's from VLED.
    http://www.vleds.com/5k-white-6-led-...3w-1-pair.html
    Note, non-tech are 9005 as they are dual mode DRL and high beam.
    Fog lights: H11. Though most would just go for HID's. There is a metal shield that limits allowable depth for HID's and long LED's. One can simply use a long nose plier and crimp the shields off.
    http://www.vleds.com/6k-white-28-led...11-1-pair.html
    Front turn signal : 1157NA. Quite a huge selection of this bulb type as it is quite common bulb size for turn signals.
    http://www.vleds.com/amber-1157-21-l...57-1-pair.html
    Rear Brake: 7443
    Rear turn signal: 7440
    http://www.vleds.com/bulb-type/tail-...amber-led.html
    license plate light: 194. Huge selection of these.
    http://www.vleds.com/bulb-number/min...25-1-pair.html
    Reverse light: 921
    http://www.vleds.com/bulb-number/min...79-1-pair.html
    Interior:
    Front/rear map light and rear cargo light: 29-31mm festoon
    http://www.vleds.com/bulb-type/festo...-29mm-led.html
    Vanity uses VANITY festoons with flat end caps.
    http://www.vleds.com/bulb-type/festo...anity-led.html
    2013 Mazda CX-5 Daily - GT, Tech Pack, AWD, Black Mica, Sand/White Interior, LED everrrryyything, Morimoto XB LED Foglights
    2004 Mazda RX-8 Driveway/AutoX Queen - KW Varient 3 Coilovers, Cobb AP + Tune, Progress Tech Sway Bars, Enkei RPF1 + RE11 in 275, Greddy Evo TT Catback, BHR catless midpipe, BHR coils, BHR motor mounts, Racing Beat intake snorkel, AF Short Throw Shifter, etc etc.
  2. #2
    Join Date
    Dec 2008
    Location
    NYC/San Diego
    Posts
    1,782
    I have not seen this posted by anyone yet. DRL LED light bar add-on cover for the two fog light faux vents.
    http://www.showeller.com/product/Day.../1203/195.html
    Another one.
    http://www.ath-hinsberger.de/tuning_...16/Mazda-CX-5/
  3. #3
    Registered Member stromdriver's Avatar
    Mazda CX-5 Touring w/bose-tech
    Join Date
    Mar 2012
    Location
    cny
    Posts
    603
    you need to make sure and post that the p13w drls are only for tech package equipped vehicles
    non-tech really can't get led drl replacements since it also doubles as the high beam
    also, the ones vleds show i've seen several things on it saying the light output diminishes greatly after any extended time driving because the cree's heatup a lot, i wouldn't recommend those, jdmtuning has some multi led p13w's that are very bright and dont suffer any ill effects from running for any period of time
    also i'd suggest checking superbrightleds.com for bulbs (other than p13w's) they have a great selection of types, sizes and colors, and tons of technical information about the bulbs, more so than any other site i've seen
  4. #4
    Join Date
    Mar 2012
    Location
    cny
    Posts
    603
    Quote Originally Posted by SayNoToPistons View Post
    no price? and chrome?
    yikes, 400 bucks???
  5. #5
    Join Date
    Dec 2008
    Location
    NYC/San Diego
    Posts
    1,782
    Not asking anyone to buy them. Just throwing them into this thread.
  6. #6
    Join Date
    Mar 2012
    Location
    cny
    Posts
    603
    and i was merely commenting on them, if those first ones came in black and were reasonably priced they'd be nice
  7. #7
    Registrierte Benutzer Chris_Top_Her's Avatar
    Donated: $40
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    5,183
    Has anyone replaced the rear flashers (brkae lates too even) with LED's, and did they require a resistor. My front (switchback) flasher leds required a resistor, oddly enough in emergency light mode they blinked at regular speed, but with the flasher they blinked extra fast. Not really anywhere in the rear compartment to mount a resistor without melting something; nor are there any good attatchment points.
  8. #8
    Registered Member
    2014 Mazda CX-5 FWD Touring
    Join Date
    Jan 2013
    Location
    Austin, TX / Tempe, AZ
    Posts
    152
    Thanks for starting this thread. I don't see myself immediately changing out the lights, but I will probably end up buying LEDs as spares and keep them around so as the lights go out I will replace with LED (in pairs of course where applicable).
  9. #9
    Join Date
    Dec 2008
    Location
    NYC/San Diego
    Posts
    1,782
    Quote Originally Posted by Chris_Top_Her View Post
    The resistors shouldn't get too hot unless you plan on leaving the hazards on for a long period of time. Granted resistors work by exchanging electricity into heat. You can try protecting nearby components with heat reflective tape if you are worried.
  10. #10
    Registered Member
    Join Date
    Jan 2013
    Location
    Alton Bay, NH
    Posts
    3
    Figure I'd post these up. I made these for someone. I think he's on this site. Those rear reflectors in the rear bumper, well they don't light up at all, so I made them light up. Made some custom LED modules:
    Hopefully I can get some installed on the car pics soon.
  11. #11
    Registered Member IHeartGroceries's Avatar
    Mazdaspeed6
    Join Date
    Oct 2010
    Location
    USA
    Posts
    816
    ^ VERY cool. Now, if only they were smoked.
    New Ride - 2013 Ford Taurus SHO, 402A & Perf. Pkg., S4 93 Oct Livernois tuned, weekend warrior
    2013 CX-5 Touring w/ Tech, wife's car
    1972 Chevrolet C-10 Custom 350/350, work horse
    2002 Dodge Neon SXT, commuter
    1967 Buick Skylark - 300/300, cruiser
  12. #12
    Registered Member
    Join Date
    Jan 2013
    Location
    Alton Bay, NH
    Posts
    3
    Quote Originally Posted by IHeartGroceries View Post
    I'm sure you can get some smoked vinyl or film for them.
  13. #13
    Registered Member
    2013 Mazda CX-5 Sport AWD- liquid Silver
    Join Date
    Nov 2012
    Location
    Minnesota
    Posts
    113
    Quote Originally Posted by apkarian100 View Post
    Those turned out GREAT. Is is something the average Joe could do too?
  14. #14
    Registered Member
    Join Date
    Jan 2013
    Location
    Alton Bay, NH
    Posts
    3
    I think the average Joe might have complications attempting it. It requires opened up that module properly and making a custom circuit board full of LEDs. I've been doing this for a while so it comes easy to me, but I'm not sure it would be the same for a lot of people.
  15. #15
    Join Date
    Dec 2008
    Location
    NYC/San Diego
    Posts
    1,782
    Installed 68 surface mount LED (each) units. Good luminosity that is equal if not better than incandescent P13W bulb. Forward light distribution is better also as the high number of LED's lights fill the DRL housing better. A nice white light. Horrid cellphone pics is all I have for now. THe crappy camera sensor threw off the hue to make it more blue than it actually is.
Similar Threads
  1. HID lighting help please
    By zackmac in forum Protege5
    Last Post: 12-25-2012, 10:10 PM
  2. Lighting ifo
    By plum in forum CX-5 Accessories & Appearance
    Last Post: 07-11-2012, 07:45 PM
  3. Lighting
    By DR8907 in forum Mazda How-To
    Last Post: 01-04-2006, 08:05 PM
  4. lighting...
    By Javo in forum Pics & Builds
    Last Post: 02-13-2005, 02:26 AM
  5. HID Lighting
    By Protege73 in forum Mazdaspeed Protege
    Last Post: 02-09-2005, 03:39 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
