CorkSport.com is MAZDA PERFORMANCE!
Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 244
Thread: Installshield's NA Build
  1. #31
    Gothenburg Superiority Installshield 2's Avatar
    Join Date
    Aug 2003
    Location
    Hollidaysburg, Pa
    Posts
    3,058
    #3 Cylinder Head
    The FS (and FP engine) utilizes a dual overhead cam 16 valve cylinder head...which is pretty common among modern engines, although unlike most current engine lines...this Mazda engine family never used any form of variable valve timing control...The profile of the cam lobes are all you get, and there is nothing controlling them other than a belt connected to the crankshaft...Entirely 'physical' design like this doesn't limit your control as much as you might think, but it will always involve some compromise on how you want the engine to perform...Systems like V-TEC are NOT why a Honda K20 can spin to 9000rpm...its simply why a K20 can spin that high, yet still have a completely quiet and smooth idle...
    in our case...we don't have that option...if you want revs...you have to sacrifice some smoothness and torque availability down low...
    the way a head works is straight forward...there are 4 valves per cylinder...2 intake, 2 exhaust...2 cam lobes are positioned for each cylinder, per cam...so the intake cam has 8 lobes total, 2 for each cylinder...same for the exhaust...and the lobes are ground as pairs, so that each intake or exhaust valve per cylinder is moved at the same time, duration, and length...basically, it all works in pairs...
    This is about as simple as a DOHC head could be...As far as the computer is involved, the only thing it is watching is the position of the exhaust cam (a sensor that reads magnets on the cam shaft's sprocket)...and the position of the crank...by comparing that data as the crankshaft turns, it knows which cylinder is at what position, and therefor when to inject fuel, and when to ignite the mixture...this, commonly, is refered to an engine management system's 'triggering'...
    The cams themselves control the valves...and because of that, the specifications of the cam lobes are directly related with how the engine breathes...They are the gate keepers for letting air in, and letting exhaust gas out...and are easily the most complex parts of the entire engine, design wise...small changes to certain specs of a cam can make some really good...or really bad...changes to its performance...The lobes interact with 'tappets' that are mounted onto the valve's stem...the lobe pushed the valves into the chambers. Under the tappets, a retainer and stem lock is in place, that houses valve springs...the springs push the valve back to closed as the cam lobe leaves the tappet surface...head design such as this will have every valve closed when the cam is either not in place, or the lobes are not pushing on the tappets...
    For the most part...there are 3 different specs to worry about with a particular pair of cams (there are more, but I'll have a specific cam article soon)...
    duration: the amount of time, in rotational degrees, that a cam 'lifts' the valves (usually measured at .050" of lift for comparison to other cams)
    lift: The amount of measured distance the valve is physically 'pushed' into the chamber
    overlap: The amount of time, in rotational degrees, that the exhaust valve remains open while the intake valve begins to open
    As far as modifications to the head itself, it gets pretty limited for the DIY type of guy...Nearly everything, other than assembly or removal of the parts...needs to be done by a proper machine shop...The head has a cast-in series of ports for the intake charge and the exhaust pulses...These ports, in certain cases, can be machined to larger diameters, have angles in them changed or removed, and the surfaces polished...again though, work such as this is pretty much impossible to do accurately yourself...and its very expensive and time consuming to have done correctly...Same with the valves...you can increase the size of the valve seats, and use larger diameter valves...but at a significant cost...for those reasons, this will be one of the very last modifications i look in to...
    Modifactions to these areas are actually very complex when it comes to tuning. A streetable engine has to be able to operate effectively in a lot of different speed ranges...It needs to have the flow speed to get a nice gulp of air right off idle to get the car rolling, and has to be unrestrictive enough to breath effectively that high revs i'll be running...Getting all these variables right...isn't easy...bigger cross-sectional area of the ports slows intake charge speed down, which dramatically decreases low end performance...you can even get it so wrong that you can create intake 'reversion', which is where the air will simply stop moving in the correct direction...fouling up the maf readings...and making the car literally inoperable...
    With that said, its not something to take lightly...and the LAST thing to do is do these mods before i have the parts in place in other areas to take advantage of it...as in...i'd end up with all of the disadvantages of a free flowing head at idle and low rpm...and couldn't yet take any advantage of the high rpm benefits...
    but since the cams are all directly controlling those valves...you can use different cams to change all kinds of things related to the opening and closing of them...
    So to quickly go over that (i'll get more specific later on)...you can run cams with more duration to keep the valves opened longer, you can run (very slightly in our case) higher lift on the lobes to open the valves a little bit farther...and you can incorporate some more overlap to have the exhaust cam open just a little longer when the intake valves begin to open...this overlap number will correlate with something know as scavenging, which is where exhaust pulse vacuum in the exhaust system will begin 'pulling' elastic air volume into the chambers...even BEFORE the intake stroke utilizes its own vacuum to move air in...
    there will be A LOT of info coming on overlap soon...Now that we have all the physical parts of the engine wrapped up, i can go into further detail about how all this stuff works together...things like dynamic compression, pressure bleed, scavenging by using proper exhaust diameters, intake systems, etc...as well as simple adjustment to cam timing by using adjustable cam gears...
    "I am a Union Delegate" -Henry Hill '63
  2. #32
    Join Date
    Aug 2003
    Location
    Hollidaysburg, Pa
    Posts
    3,058
    Quote Originally Posted by tweety2300 View Post
    There is already more usefull information in this one thread than the entire Wikipedia database
    thanks man, glad you feel that way...
    I've only touched the surface with specifics...nearly everything so far has just been 4 cylinder engine related, in general...Hopefully by the end of the week i can have a lot of info on cam timing, as in adjustments one can make on his own with a set of adjustable gears...and start getting info out that is completely relevant to these engines, rather than 'everything'...
  3. #33
    Registered Member Mookhaasa's Avatar
    2002 MP5
    Join Date
    Oct 2012
    Location
    Va Bch
    Posts
    199
    Thanks for posting all of this. I like how you break it down.
  4. #34
    Purple Drank Tuning 2.0t03speed's Avatar
    08.5 CWP Speed 3
    Join Date
    Mar 2007
    Location
    Virginia Beach
    Posts
    8,240
    i'm happy i was able to contribute to this build =)
  5. #35
    Join Date
    Aug 2003
    Location
    Hollidaysburg, Pa
    Posts
    3,058
    ^^yeah thanks again man, especially with putting up with the journal questions before the purchase...The info you gave let me find the original buyer in a couple of minutes, and everything checked out...
    Leaving work now, and will get the valve cover off again to adjust the overlap and check lash tonight...finally warming up around here, so a decent evening to work on this stuff...
  6. #36
    Join Date
    Aug 2003
    Location
    Hollidaysburg, Pa
    Posts
    3,058
    So I took the valve cover off tonight, check all tappet clearances, and adjusted the gears a little...
    I retarded the intake cam 2* and advanced the exhaust 4*...taking 12 degrees of overlap down to 6, roughly...idle was dramatically improved, actually too much imo...and absolutely no stalling now on throttle lift...im probably going to advance the exhaust back another 2*, trying to meet an impossibly awesome idle w/ stalling to a stock like idle...in the middle...not that i'm after just idle, but i'd like to run as much overlap as possible with the stock ecu...as i've already got a pretty competent exhaust system bolted on...which could take great advantage of that...
    now the bad news...on the exhaust cam...my quick steel plug had started to back out of the cam shaft end...I followed all directions, had seen some similar things done with it (mostly on motorcycle engines), and allowed enough time for a full cure...but it seems to have not worked...it was pushed out of the cam end about 2mm or so...all in tact, not pieces or anything, and the lip on the air box side of the head prevents it from coming out any further...tonight i was only able to simply press it back in by hand, but thats it for now...that cam needs to come out for some lash adjustments anyway, but i'm reluctant to not get the intake cam out also...and simply plug those things some other way...I felt like it was 'too easy' to begin with, but live and learn...
    car will be grounded for a few days until i can figure out the logistics of fixing this, a clutch flywheel install, VTCS removal...etc...all in the next few weekends...
  7. #37
    Registered Member AusOrion's Avatar
    Mazda SP20 sedan (MP3)
    Join Date
    Jan 2007
    Location
    Brisbane, Australia
    Posts
    470
    Quote Originally Posted by Installshield 2 View Post
    I have been wanting to adjust my Twiggy's in order to close the overlap to improve the idle (as I let the stock ecu control the idle rather than the Microtech) and also to get better midrange power. I know which direction to move them but was wondering how much would make a difference. This will provide a nice guide to how much to adjust each cam.
    Keep up the good work!
    Exhaust: Autoexe header; Custom midpipe; Racing Beat catback
    Engine: AWR mounts; Twiggy cams; Custom CAI; RR Racing UDP; PS cooler
    EMS: Microtech LT-10; J&S Safeguard; Bosch coils
    Gearbox: MSP LSD; Fidanza flywheel; 626 5th gear
    Rims/Suspension: MX-5 17x7 rims; Tokico Illumina; Eibach Pro-kit; Progress swaybar, AutoExe strut brace
    Exterior: MSP front lip & rear spoiler; EDM tails
    Interior: JVC AVX-77; Autometer gauges; DaveBs; B&M shifter
    Projects to come: Matt V headlights, JDM mirrors, AutoExe grill, Vibrant vac block
  8. #38
    Join Date
    Aug 2003
    Location
    Hollidaysburg, Pa
    Posts
    3,058
    ^^thanks.
    If you haven't adjusted it yet, it must be because of US vs. Aus stock computers (for idle, at least)...as we have nearly an identical exhaust system it looks like...I still have the VTCS butterflies in the IM, so i'm sure that can mess it up some...but it would stall more often than not, and even popped a p0300 code just as it stalled at one point...
    But like i mentioned, the amount of overlap i closed was pretty heavy...I'll definitely be messing with that more when i re-plug both cams...ideally i'd like to raise the idle 150 or so rpm...as that will definitely allow more overlap...and i know of this phantom procedure using a jumper wire to short some of the diagnostics while you adjust the idle screw.... which makes the ecu not learn around the adjustment. But my manual that illustrates it is for a different FS equipped car (a 626), and the FSM just lists all these different SST's for it...so i'm still digging...
    Anyway though, i'll put up my findings with how the engine responds with adjustments...The basics have been posted on here before, but its pretty hard to find...and more importantly its mostly just rehashed stuff from other forums, not changes people made on these specific engines and the results of it...
    so far i just stayed safe...most engines are a little more picky about intake cam adjustments, as the intake system is usually a lot more restrictive and complex than the exhaust system...its also fundamentally easier to push air than it is to pull it...so thats why i only went 2* on the intake to start...when closing overlap, you have to remember that the exhaust stroke, and valve closing event, is the FIRST event related to overlap...the opening of the intake valves as the piston approaches TDC of the exhaust stroke...is the SECOND event...
    so anything that makes the exhaust valves close sooner (advancing the exhaust timing) or the intake valves open later (retarding the intake cam)...will close overlap in the specific degrees of your adjustment...
    and so far we know 6 degrees of overlap (with a 1:2 exhaust bias) is too stock like haha...12 degrees for me at least (no bias) was not streetable...so i'll find something in the middle...
  9. #39
    Join Date
    Aug 2003
    Location
    Hollidaysburg, Pa
    Posts
    3,058
    Oh and one other note...
    2.0t03speed is helping me with this, but if anyone else knows too it would be great info to have...shims...anything you have, i'm all ears...
    The twiggy exhaust cam has a changed base circle in order to keep factory spec ramp angles between the lobes and tappets...So the exhaust side lash should be between .020" to .024"...intake side lash can be the same as factory spec (.010" to .014")...
    I checked all 16 valves last night...all 8 intake valves are perfect at .012" (kind of crazy after 156,000 miles)...
    the exhaust side's 8 exhaust valves are a little tighter than needed though...cylinders 1,2, and 4 are all .018", and cylinder 3 is .017" on both valves...
    i've found the 'adjustment disc' part numbers and everything...and it seems they're a dealer only item, which is fine and still relatively easy for me to get...but i don't know what i'm starting with thickness wise...I can't find the factory stock thickness that is currently in there, and i'd rather order this stuff before the cams come out again...I know I need to increase roughly 8 tappets by .002" (2 of them .003") or so...but i don't have the numbers to start...
    I'm giving Ryan a call after i get some other work stuff going, and i'll report back what i'm told...but anyone that already knows this; feel free to fire away...can't find it anywhere on the forum...
  10. #40
    Registered Member
    03 P5, 13 CX5
    Join Date
    Sep 2004
    Location
    behind you
    Posts
    2,956
    KJ01-12-599/T=3.550MM
    Z502-12-545/T=3.052MM
    Z502-12-552/T=3.100MM
    Z502-12-558/T=3.148MM
    Z502-12-565/T=3.196MM
    Stuff like that?
  11. #41
    Join Date
    Aug 2003
    Location
    Hollidaysburg, Pa
    Posts
    3,058
    ^^yeah, man...thanks.
    Do you know which is the size used from the factory? Like which size mazda starts with?...I'm hopeful factory tolerances are close enough that they start with one specific shim, and offer the others simply for overhauls...that way i can easily order the sizes i need for the exhaust side right away...the dealership dude had no clue...figures...
  12. #42
    Join Date
    Aug 2003
    Location
    Hollidaysburg, Pa
    Posts
    3,058
    Just talked to Ryan (2.0T03speed) and it seems there is no 'factory' shim spec...they are shim'd accordingly at the plant...
    So that slows me down a little...i need to get the cams off again (oh well, had to anyway) and measure all 8 exhaust discs...and go from there...
  13. #43
    Registered Member
    03 P5, 13 CX5
    Join Date
    Sep 2004
    Location
    behind you
    Posts
    2,956
    yeah that is what I thought too. That is why I numbered mine as they came off.
  14. #44
    Uxor Sport23's Avatar
    Donated: $25
    2003.5 MSP
    Join Date
    Jun 2008
    Location
    OKC
    Posts
    799
    I just came across this the other day. The shims for Miata should be the same size. Adding the Nissan shims to the list will give you a lot more options. link
    dowhanow?
    (boom07)
    (msptitani (redp5)
    #378 03.5Titanium MSP
    '88 RX-7 Vert
    '02 Black P5 - RIP
    '02 Red P5
  15. #45
    08.5 CWP Speed 3
    Join Date
    Mar 2007
    Location
    Virginia Beach
    Posts
    8,240
    He shouldn't have a problem getting the thicker shims for the exhaust side. He just has to figure out what sizes he needs. They are only $8 a shim so not terribly expensive.
Similar Threads
  1. EBellis Mazda3 Build (mild na build)
    By EBellis in forum Mazda3 Lounge
    Last Post: 07-25-2012, 06:54 PM
  2. if you are intersted in my build as well as the other build..
    By probeturbo in forum Mazda6 Engine & Transmission
    Last Post: 11-15-2010, 02:56 PM
  3. if you are intersted in my build as well as the other build..
    Last Post: 10-22-2010, 08:38 PM
  4. MS3 engine build/PTE 5557 build completed
    By Cherryvodka in forum Mazdaspeed3
    Last Post: 04-29-2010, 02:58 PM
  5. installshield 2(2)
    By twilightprotege in forum Mazda How-To
    Last Post: 04-26-2005, 11:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
