ok so this ones gonna be a story..... while doing alternator i had car on ramps/in gear when i crank on bolt car would roll off. it went into gear etc. still... parked car for a couple days. i went to garage yesterday to start some new projects. the car was parked on some snow for what its worth. i got in an started it and when to reverse but nothing just high revs... tried first same thing. my wife then came over to try n give a hand and pointed out wheels werent moving at all..... now car had a high idle (1,500 RPM) now it doesnt but it does not move.... i personally preferred high revs. if i buy new clutch pressure plate release bearing and flywheel will this fix my problem? its something i was gonna do anyways but really didnt want to at this point
also when i put car in gear i can feel it... like the slight thud... so i dont think its the cables, also no weird sounds etc so kinda second guessing the problem being a clutch.... thinking more along the lines of axel default/ malfunction. I dont know the technical term but where the axel splines go in the tranny... could they be stripped or could this be a center link issue? anyways everyones been great and very logical so for so hoping this will be the same. i look forward to the comming input. and thanks in advance guys.
