C chromer75 Member : 03 protege 5 wgn 2.0l Dec 30, 2012 #1 2003 protege 5 wgn 2.0l auto. I have a front end vibration that shows up between 45- 60 km/h under load,gets pretty bad. Looked at axles,sway links ball joints on driver side..any suggestions greatly appreciated!!!!!! Thx Will
F Fresco Contributor Dec 30, 2012 #2 Check for an improper wear pattern on your tires, also check to see if your rims are either dented or bent, and see if you need a wheel balance
N natebryant88 Member : 2011 Mazda CX-7 SV Dec 30, 2012 #3 Road Force Go by a reliable auto shop and ask for a road force balance. This will tell you for sure if its a tire problem.
