I found out the "Crosstek CUV" is sold only through certain stores... BigO, NTW. They have similar lines for other distributors. Seems a little odd, but they have multiple exclusive lines. The one I got is called the NT850+
The reason tire manufacturers have "exclusive" lines is because large retail chains want a tire they can add higher mark-up to and not be undercut by a competitor offering the same tire at a lower price. These tires are generally of mediocre quality (or worse) with their best attributes often being cost and long life at the expense of poor traction and steering response. I avoid all tires that are only available at a specific retailer.
18x8 Sparco Assetto Gara's with 235/60R-18 Bridgestone Dueler H/L 422 Ecopia.
I took it for a quick spin up to highway speeds to check for shakes and shimmies, tested good. I will let you know about peppiness, regarding the lighter wheels.
They don't make different lines so they can sell inferior product.
Good looking wheels. I guess it's not too remarkable that they look similar to my OZ Alleggerita's (considering that OZ engineered them). And a loss of 9 lbs. per wheel? That's excellent!
I guess the weight savings is significant in both the tire and the wheel when moving from 19" to 18" wheels.
After you get them installed, let us know if you notice a little more peppiness from having less rotational inertia.
Wheel weight makes a bigger difference than is immediately apparent to most people because there is (in addition to the actual weight) something called rotational inertia. Whenever the vehicle changes speed the mass of the wheels must be moved IN ADDITION, the wheels must be spun to the new speed. Picture a wheel on a wheel stand that is spun up to 60 mph using a stationary bicycle with a chain and sprocket and appropriate gearing. Worked up a sweat, didn't you? Now, put on a leather glove and bring the car tire from 60mph to a stop in 10 or 20 seconds. What happens? Oh, the leather glove got hot and burned you? That heat represents the amount of energy it took to get the tire spinning. On a car, multiply that times 4 (four wheels to spin up). Now do this a hundred times a day to simulate normal traffic. Yes, lighter wheels save quite a bit of energy.I got to say, I am not totally convinced that shaving 9 lbs a wheel 36lbs total could make any difference. That is like a person that is 36lbs lighter getting better zero to 60 time.
My CX-5 with new Enkei M52's...
Had my 18s on for a week, and I'm pretty much convinced that Mazda would sell more of these things if they used a lighter wheel and a little stickier tire. Going from the Geolanders on the stock 17s to Eagle GTs on a lighter 18" wheel feels like changing from winter tires to summers. Handling and ride improved, maybe a little quieter. No noticeable change in MPG so far (I'm still using 225s).
Sticky all-seasons 18's make sense for enthusiasts.
Unfortunately for the typical consumer (which makes up most of the market), It wouldn't get the styling points of the 19's, nor would it get that +1 highway gas mileage from LRTires that manufacturers and consumers strive for.
There's an oxymoron if I've ever heard one!Sticky all-seasons 18's make sense for enthusiasts.
