I have a random missfire issue that I can't track down my root cause. started with a misfire on cyclinder 4, pulled the plugs and the gap on cyclinder 4 was too small. Replaced all plugs, still have a slight misfire when accelerating from a stop in 1st gear at aprox 1500 rpm, but no code. also had a slight stumble at idle.
I noticed the the more gas from a stop the more noticable the mis. so i put the car in 2nd(sport shift) and put more load on the car and the car boogs horribly up to about 3k rpm, and throws a misfire code cyclinder 4. pulled plugs everything looks fine.
under had acceration in 1st I have gotten cyclinder misfire on 1,3, and 4, all seperate occasions weeks apart. I figured cyclinder 1, 4 mis was becasue of the coil pack. replaced both and issue is still there but no where near as bad. checked the resistance on the wires and the resistance was ok, no high resistance.
Im going to replace the plugs again because in thinking 1k miles on failing coil packs didnt do the plugs any good. Any thing else that im missing? I was thinking of doing the compression test, pull the valve cover and check the timing, and maybe seafoam the motor. All this has been getting progressivly worse until i replaced the coil packs.
Car is an 2003 p5 sportshift 142K miles.
I may upload a video of it if that will help.
