The fuel pump and injectors in an MSP are the same as in the regular proteges and P5's. You shouldn't have anything to worry as long as you have the MSP ecu and you're turbo and oil setup is correct.
I have an oil only setup for the T3. I have a Oil filter sandwich plate that goes from there to the turbo. For the drain line, I have a -an fitting from turbo with a hose that is in a block fitting on my AWR oil pan.
