alafya, mpnret,
count me in as another person deciding between the new forester and the 2.5L cx-5.
waiting for the final specs to be released, crash test results for the forester, and test drives before making my choice.
(2thumbs)
by the way, don't forget the cx-5 has it share of issues: transmission clunk, rough startup, hood/mirror vibration,...
The rough start-up is by design. The engine adjusts ignition timing to heat the catalytic converter to reduce cold-start emissions per EPA standards. The reason for the adjusted timing is because the first catalytic converter is pretty far away from the engine block because of the 4-2-1 header system. In any event, there is no problem there. It's running as designed.
The transmission "clunk" you mention is also a characteristic of the SKYACTIV-Drive transmission. A notable fuel saving effort involves a strategy to reduce engine load after coming to a stop while still in drive with the brakes applied. Reaccelerating from this state may be of concern to the customer; however this strategy, as well as the torque converter lock-up strategy is normal and the nature of how SKYACTIV-Drive operates.
The mirror and hood are well documented, and mine does them too, but I don't think it is a big concern.
With every first year model, there are always a few bugs. Im sure the Subaru will not be immune to them. There have been complaints of unrealistic fuel economy with the Impreza, which has the same CVT the new Forester will have.
