mazdachris
- Mazda CX5
Hi guys, I just changed the oil my self at 5k miles with the new Mazda Genuine GF-5 0w20 with Moly and I got improved gas millage. I am not sure if it is because it is first oil change (e.g. factory oil thicker?, different?) or its a result of the new oil (I believe that) but I immediately got improved gas mileage. Before I announce the numbers need to say that it is the Sport Manual (so you don't get shocked).
Before: 60 mph ~37-38 mpg, 65 mph ~ 34-35 mpg (50 miles highway, cruise control)
After: 65 mph ~40 mpg ( (50 miles highway, cruise control).
It is exact same route. First day after the oil change I though it might be a reversed wind, so I waited a few more days. Same results both direction (e.g. not downhill/uphill effect). This is in Chicagoland.
When I mixed it with some city driving (more like suburban driving) I currently have it on 37 mpg avg with ~40 mph avg speed. I should also say that I have about 100 pounds weight in the trunk at all times.
I am just blown away from this vehicle. I used it for business and thanks God I did not buy some heavy burner so called "truck".
I hope this tech is also reliable! Thank you Mazda!
P.S. Someone please confirm if you have similar results after the first oil change with different brand oil.
EDIT: For those unaware, this oil has perfect characteristics. Here is a detailed information about is. That is the reason to chose it. I had some hard time finding it with local dealerships for a price under $8 a quart. Currently, ROTO in Arlington Heights should have a case and should be able to sell to you for $8 (or less) if you get a dozen. You can also order onlie - the cheapest places I found is HandAaccesories (google it) ~$6.50 a piece + $20 shipping for a dozen and Arlington, VA Mazda (just a bit more, but if you live there you can pick it up and save the shipping cost).
UPDATE:
Almost a month later and I will have to disappoint you. I never managed to repeat those "crazy" numbers posted above: same route, similar conditions, same gas stations, same speeds. However, the week I got those ~40mpg numbers was very warm 70+ F. Since then, it has been always cold - under 45 F. My conclusion is that the car generally burns more fuel when its called outside. And while this will be no surprise for short city rides, I can not explain why it is happening on long highway trips (50-60 miles). And by that I mean a difference of 2-3 mpg on the current fuel gauge, and so the average (my car stays in a garage and I start and go - no warm up idle. In addition the highway entrance is 1.5 miles away). Could the heater ( I keep the interior pretty hot) be the reason?
Overall, it still has better fuel economy with the new oil, but difference is not as much as I though.
I just purchased a case of it online from the US. Plus some filters. My dealers around here don't know what it is. My mileage dropped as soon as the cold weather hit. Still, better than what my 07 3 did this time of year. Engine are small and do not generate that much heat anyway. With heat and lights, bound to affect mileage. Best way is to block the front at the grill. This keeps wind chill off the rad. Engine has an easier time staying warm. Will warm up faster on short trips as well.
