dragonballspeed
- 03 Mazdaspeed, Orange
UPDATES: Pictures changed or added as they become available and may not necessary line up with the original date of post.
I have never posted a build thread, and have been a part of this forum for nearly as long as it has been around. I started with a 2003 MSP bought from the dealer, and as many of you know its all been downhill since then. I kid as if that was truly the case, I probably would have let it go a long time ago. A lot of the changes have been very slow to come plus the car has been sitting still for about 3 years now. Mostly bc I was taking my time to identify wher I would go next. So here ya go with a little bit of back drop to get caught up.
This was shortly after purchasing in 2003
Here we are about a year later with super low stance and full 3" exhaust. Hell, this was before anyone even considered making 3" exhaust! An engine build was also commisioned that same year.
I left TX in 2005 while my car was still in the shop having a full on audio build done, as well as having the headliner redone in the same matching orange suede Right about the same time I installed a custom 14" Wilwood BBK from Revolution brakes front and rear. I was gone about 2 years, and during that time I only drove the car a handful of times until I moved back to TX.
Fast forward to 2007, and this is probably one of the best pics ever taken of my car IMO. I ended up trashing the RH Evo wheel from the bake pics due to nasty curb, and replaced them with a set of 19x8" G-Games by Rays this timw with a whole lot better fitment and offset. At this point I was also running a Haltech E8, an AVC-r set around 1 Bar, custom FMIC, oil cooler setup, and aluminum radiator all by PWR. AWR motor mounts and endlink kits were also installed with some JIC coilovers
Around 2008 I came to the full realization that I had been thoroughly screwed by the shop that was going to build my motor, as well as dealing with constat electrical gremlims from the audio install. I sued in small claims, won, and never got a damn thing from it other than lessoned learned. During that summer, my car finally became victim to the notorious boom-boom that our cars are so well known for. Blown head gasket. Tore the engine down replaced head gasket only to discover that the rings were totally shot. Drove it home and parked her.
At this point I tore into the audio system only to find I was melting wires due to poor grounds, thus started the permanant tear down that brings up up to date.
Over the past 3 years or so I have completely stripped out all of the Dynomat that was installed in '05, removed all wiring of any kind, sold off all bits that were usuable to someone else, and left myself with a shell. My final goal is a purpose built NASA TT car. The only problem is that because of the equipment I have purchased over the years and will reuse, I will have to compete in a much higher class than most MSP's.
December of 2011 first half of cage build complete. Due to price going a bit higher than anticipated, I had to pull the plug a bit early. However the rest of the cage work will be performed at a later time.
Before
After
Additons to be completed: diagonal, x-brace, door bars & window nets
Summer of 2012: I have never liked the core support on these cars as nothing is symetrical, so I cut it all out and i'm in the process of rebuilding out of tubing. I also hated the stock braking system in conjuction with my BBK, so I cut a hole in the firewall to allow placement of a foward swing triple MC setup from Wilwood that better matched my calipers. It took a bit of work to figure out the placement of pedals to work with stock column, but well worth it in the end.
Before
After
Where it sits with body parts hanging waiting for paint
That's the story in a nutshell. Acutal build to continue.
Current Mods going back on car:
'95 Millenia KLde square port (rebuilt) with kl31 heads, ZE-IM, and COP conversion
Haltech E8
Transmission with welded LSD and Cryo treated internals
AWR motor mounts, trailing arms, swaybars, & endlinks
AWR strut tower bar - new 3 point design (commissioned by me) - Anthony would really like it if others purchased this bar
Wilwood forward swing pedal assembly w/Triple MC's & bias control knob
Wilwood rotors and caliper
Cobra Imola II driver and passenger seats
350mm Momo steering wheel
Sparco Hud Adapter
Lifeline quick release hub
PWR intercooler, radiator, & oil cooler
Remote oil filter hosing
-AN braided lines for everything
3" exhaust & headers
roll bar steering column mounts
Master disconnect Kill switch
Full rewire using 12 circuit kit
AVC-r
Full Roll Cage
Tubular upper & lower core support w/lower transmission mount
Tubular crash bar
Future Mods:
Fuel Safe 12 gallon fuel cell
Schroth Racing 4-point harnesses
4 nozzle fire supression system
3 quart Accusump
17" wheel with 245/40/17
AAC link kit
Adjustable front control arms from Dominant Engineering or similar design
Boost
Before
After
Before
After
Haltech E8
Sparco Hud Adapter
AVC-r
Full Roll Cage
Tubular crash bar
Future Mods:
3 quart Accusump
AAC link kit
Boost
