ZoomZoom03
- 2003 Mazda Protege 5
So quick question (hopefully): I have had an Optima Red Top in for over 7 years. Running aftermarket stereo with amp, head unit and sub (nothing crazy) and plug & play HIDs along with Unorthodox UD pulley. Ever since I switched to UDP, i have had problems with squealing belts (normal from what I've read). One mechanic got it right finally fro a couple of years then I had belts, water pump, etc done and voila squealing belts again. Belt squealing is temporary and goes away after a couple of minutes. I have a volt gauge attached and noticed at 14 there is no squeal with lights off. The second I put lights on it drops to 12 and squealing starts. At this point I am sure that belts are getting chewed up again and need to be replaced, but I am curious if a dying battery could also be contributing to issues. If I leave the car in the garage for about 3 days or more it is almost guaranteed to not start and requires a jump. Thanks in advance, just trying to finally solve the issue and stop annoying the neighbors
