2002 Protege5 Automatic 161,000 miles Don't know if original CV axles (had car since around 88k)
This is my son's car but I do the work on it if he keeps up the grades. W/o boring you I will try to keep it short.
Car felt as if a tire was out of balance or about to come apart at the threads when driving causing a loud noise (boom boom boom boom).
(apparently this has been going on for a weeks)
The tires are good and CV axles SEEMED to be okay. It sounded like the noise was coming from the front right side. After checking a few things my neighbor and I figured it may be a wheel bearing and decided to take off hub assemble to check it. Couldn't get the axle nut off the front right so decided to soak the nut over night.
(next day)
I decided to lift the front left tire, keeping the right one on the ground, to make sure the noise was only happening on the right side. The noise happens on BOTH sides. I get my neighbor crank it up so he can hear the noise is coming from the left side. While I am giving it gas he tells me to stop. It turns out some transmission fluid leaked on the ground. UP TO THIS POINT THERE HAS BEEN NOT TRANSMISSION FLUID LEAKING.
We get under the car, turn the cv axle by hand and the right one seems have a slight lateral wobble and the left did not seem super tight. I DON'T BELIEVE IT WAS THIS "LOOSE" WHEN I CHECKED IT THE DAY BEFORE. (is that possible or did I just not notice it???)
Again I start the car up and slowly give it gas transmission fluid leaks again. I BELIEVE IT LEAKED WHEN THE CAR WAS SHIFTING GEARS and the shift was rough AFTER I had it in the garage to check it out...in other words the leaking is NEW - JUST STARTED while it is jacked up in the garage. . My neighbor believes the seal (where the cv axle goes into transmission seems to be where the transmission fluid is coming from.
I am about to take off the left wheel (hope the axle nut is cooperative) and check the leak AND try to see if we can find out what is causing the noise.
Does anyone have any insight as to what could be going on?
(next day)
