Page 32 of 32 FirstFirst ... 22303132
Results 466 to 479 of 479
Thread: I did it again!
  1. #466
    No words bazooka joe's Avatar
    Donated: $40
    Miata & NEMOC Moderator
    2016 Miata Club, 2014 CX5 Touring, Honda 1976 XL 175
    Join Date
    Oct 2002
    Location
    wbee ma to NC 2016 Jinba ittai
    Posts
    21,366
    Nice mike!
    Sent from my iPhone using Tapatalk
  2. #467
    Mazda for life now 6speed's Avatar
    '05 MSM #36, '05 WWP RX-8
    Join Date
    Oct 2004
    Location
    Poconos PA
    Posts
    554
    RR ABS sensor failure, got the replacement sensor yesterday.
    Scheduled full tuning for Friday the 22nd at my normal tuner's. I've got another tune with Ken Hill scheduled for August 1st, to get the firmware/hydra stuff figured out, and get a dynojet number comparison. If I go full track car with the MSM, I will need to supply dynojet numbers for classing purposes.
    Registered for another weekend at the track, Summit Point WV on June 6-7.
    Seriously considering pulling out the rest of the emissions gear and the AC hardware before then.
    2005 Mazdaspeed Miata #36
    Bought my original RX-8 back
  3. #468
    Join Date
    Oct 2004
    Location
    Poconos PA
    Posts
    554
    Running the numbers and thinking hard about what all is involved... but I'm headed more and more toward turning the MSM into a full track car AND swapping in a ~250-300whp 13B from an RX-7. Non-turbo, I'd have to have it built and ported for high compression N/A power.
    It would actually be a pretty straight forward swap, since it wouldn't be a street car. Most of the complication is getting it mounted correctly, then wiring up an aftermarket ECU. Exhaust would be a short straight run (REALLY loud), cooling would probably be reworked, but wouldn't be complicated. Can mate to the MSM's transmission with a bit of simple work.
  4. #469
    Registered Member Reitrof's Avatar
    Donated: $50
    2008 Miata PRHT; 2018 3
    Join Date
    Jan 2003
    Location
    Ottawa ON
    Posts
    7,526
    Mike, can ever just leave a car alone?? I amazed at what you think of next.
    Bruce
    2008 Miata Touring PRHT True Red, MazdaSpeed body kit
    RB Intake, RSII Exhaust, RX8 Sways, KW V3 Coilovers, Fiaam horn
    RX7 FD Rims, Kenwood DNX7100, Int Wiper Mod, 3M Bra
  5. #470
    Donated: $40
    Join Date
    Oct 2002
    Location
    Posts
    21,366
    He's wanted to do this for years now! It's his therapy!! [emoji2]
  6. #471
    Zoom Freakin' Zoom
    Donated: $10
    1990 RX-7 Turbo II
    Join Date
    Jul 2004
    Location
    The Streets of Cape Cod
    Posts
    17,348
    Quote Originally Posted by 6speed View Post
    My friend Lui owns Wankel Works. He's a rotary guru, can do anything with the engine.
  7. #472
    Join Date
    Oct 2004
    Location
    Poconos PA
    Posts
    554
    Quote Originally Posted by Reitrof View Post
    Well, i want a full track car. I can either use one I've got (the MSM) or I can try to recoupe a little bit of money from it and buy something else to use. If I turn the MSM into a full track car, I'd build it to be competitive in the NASA TTB class, which in part means I'd need to have the engine up to about 260whp. At that power level, I'd need to have the engine built in order to make sure it stays reliable on track. Since I'm not inclined to go budget build on something so important, I'd hand the engine off to FM for a full build, which would run me around $8.5k for the engine, plus shipping and other costs associated with removing and installing the engine. (there is a lot more unrelated to the engine on my list) I'd still have an engine that at best I would only marginally tolerate. Don't get me wrong, I enjoy how fast my MSM is, but I have never liked the BP engine. Everything I dislike about the MSM is centered in that raspy thrashy rough engine. Getting it built would probably change the characteristics a bit, probably smoother (better balancing), probably lots of tone changes from different breathing, but it would still be the same basic engine, and I don't think I could ever love it.
    Now, if instead of spending almost $10k on a built engine I pull the engine, and everything related to the engine (both ECUs, wiring harness, engine accessories, turbo setup, exhaust) I'd be able to sell it all for somewhere around $8k-9k (conservatively). I would then have about $18k on hand to cover an engine swap. And that can get me a whole lot of engine swap. A 13b can mate to a Miata transmission (might not be the MSMs) with some bellhousing swapping and milling of the transmission input shaft. The motor mounts are similarly located and could be modified for the 13b. The ECU would be an AEM, and wiring up the ECU would be a custom job that doesn't worry me. From there it is just solving the various other oil and coolant cooling items, having the exhaust fabbed up, and getting it tuned. Doable for less than $12k ($6k ish for the built 13b), even if I hand over the whole car to a shop to do the work for me, which I wouldn't need to do.
    It would actually save me money to get rid of the one part of the MSM I don't like. For more power, more reliably, less weight, more enjoyable engine, more uniqueness, cheaper rebuilds if needed.
    It's a bit of a pipe dream at first glance. Too crazy at second glance. But digging deeper it's actually very very reasonable. Not much reason not to actually
  8. #473
    Join Date
    Oct 2004
    Location
    Poconos PA
    Posts
    554
    Retuned. Not much peak gain, but if the lower comparison line is the first pull of the day at minimum boost, and you can see the torque climb angle. The tuner added quite a bit to the front end of the torque band, more rapid spool. He compared it to my highest run on the stock turbo (202whp 197wtq peak), and I'm spooling 700rpm earlier, holding boost more easily, and holding torque hugely better. The torque 'curve' before was literally just a single peak.
    The torque hit is substantial, enough that the skill level needed to be fast on track went up a notch or two.
    The peak numbers are also less favorable SAE correction than before, and still what is supposed to be a low reading dyno. I'll be on a Dynojet in August to see what the comparison actually is. So I'm ignoring the numeric values at the moment. Too much uncertainty of how they compare.
  9. #474
    Join Date
    Oct 2004
    Location
    Poconos PA
    Posts
    554
    About to pass 100,000 miles, and the MSM is going into storage soon. At some point in early spring, it will be headed to the west coast with me. The engine hasn't blown up yet, a fact that I continually find surprising.
    But I'm definitely going to be rotary swapping it.
    One of these basically, though this is in an FD.
    https://www.youtube.com/watch?v=KQkhE6BOwK4
  10. #475
    Donated: $40
    Join Date
    Oct 2002
    Location
    Posts
    21,366
    So where you headed on the west coast ? That race was exhilarating !!!
  11. #476
    Join Date
    Oct 2004
    Location
    Poconos PA
    Posts
    554
    I'm going to avoid saying publicly. This has been a very rough divorce.
  12. #477
    Donated: $40
    Join Date
    Oct 2002
    Location
    Posts
    21,366
    Sorry man! I hear they're all rough, I understand. You'll post a build thread when the times comes though?
  13. #478
    Donated: $50
    Join Date
    Jan 2003
    Location
    Ottawa ON
    Posts
    7,526
    Keep your chin up Mike.
  14. #479
    Join Date
    Oct 2004
    Location
    Poconos PA
    Posts
    554
    Quote Originally Posted by bazooka joe View Post
    It will be in this thread
    Oh I am. Things are always looking up for me in every facet of life. There are just simple precautions that I have to take to ensure my safety, and while I doubt she is hanging out this particular forum ... shrug. You never know.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
