Are all of you in the manual mode when this happens, or in both auto and manual when it happens?
Had the valve body replaced at about 12,000.00 miles. Now have 15,500 on the vehicle with no re-occurrence of the TPS, TCS, and AT lights going onmy wife is still very worried about driving the vehicle to work as the last occurrence happened travelling at speed on I95.
Certainly hope that we are wrong but feel like the issue will occur again, why this fault was not discovered during testing of the vehicle is beyond belief. What changed in the transmission design or manufacturing since testing. New supplier, or did Mazda test without the warning lights enabled?
I believe (not a mechanic) that a valve body is the part of the transmission that through slight pressure changes and voltage detection regulates the shifting between gears. It seems Mazda has recommended a computer reprogramming for some people with the same problem, while others a complete valve body replacement. This raises a question of whether the ECU programming and the valve body are an issue. So sad to see that a permanent fix is yet to be found.
Having owned used Alfa Romeos in the past, it has been a very long time since a vehicle has broken down on the side of the road. Very unhappy that this has occurred in a new vehicle.
I hope someone at Mazda is looking into this else we may have a major problem down the line (like Honda did with its earlier TL/CL/Odyssey transmission issues in the early 2000 models that led to massive recalls/extended warranties on tranny's).
I doubt it, the transmission is one of the best things about the CX-5 (I have the AT but those with the 6 speed manual say the same thing). The issue you reference does not appear to be widespread. Modern cars are very complex and yet they are more reliable than cars of just 20 years ago. But no manufacturing process is perfect and with so many parts there will inevitably be a few that fail from the start. This is true of every model of car ever made. So far the CX-5 appears to be better than average. Time will tell how it does over a longer period.
While I send my sympathy that you were one of the few that needed a new valve body, I am rather surprised you are taking it so hard. As clean as modern auto assembly plants are, it's possible that a small piece of debris found it's way into the valve body and clogged a passage. Or, perhaps the supplier of the valve body did not make 100% of the parts identical. No manufacturer checks every part 100% for compliance with their specs - it is only possible to test a small percentage. Cars are not Space Shuttles - they are mass produced. The CX-5 would probably cost in excess of $100,000 each if every part were certified for spec compliance. Honestly, it is not the least bit surprising that no manufacturer has a zero percent defect rate.
It happened to me with a similar situation climbing a mountain. All the lights flashing and the transmission cut out.
I had a code reader on me and immediately scanned the CEL code and it said:
P0847
Powertrain - Transmission - ISO/SAE Controlled
Transmission Fluid Pressure Sensor/Switch "B" Circuit Low
Shortly after restarting the car, the CEL went off and everything seemed normal. At this point the car seems fine, so I'll just wait for Mazda to figure it out before taking her in.
This code refers to the #2 trans oil pressure sender. Says for tech to check trans fluid level. Test voltage of switch. Replace switch if necessary. Providing no additional codes. Do yo remember what outside temp was?
It was around 40-50F outside. A few days before the incident I climbed a much steeper, much colder (around 20F) mountain and had no problem.
Build date is 2/12
I had my 2013 CX-5 (build date 4/12) in for its first oil change at 5k miles yesterday. The service advisor told me about this newly discovered CX-5 gremlin involving the panel lighting up and the transmission rapidly shifting down to second and staying there, limiting speed to 20 mph or so. He mentioned something about two cases in 7000 cars and that the fix so far was to "re-flash" ECU and drive it 100 miles.
I didn't think that much more about it until I checked this forum; it now looks to me like the chance of this occurrence is far higher than 1/3500, especially with an early built date vehicle. Additionally, the inconsistency of apparent causes and recommended repairs noted in this forum lead me to believe that Mazda has yet to definitely determine either. I would imagine they will eventually figure this out, but until they do, or at least until I can get a better handle on just how big (or small) a problem this is, I will be reluctant to take my vehicle on any more long trips.
Has anyone experieinced this problem with a 2014 model?
I experienced this phenomenon again merging on the interstate. I'm glad to know its the tranny. Too bad my dealer won't honor the warranty, or the other dealer 100 miles away.
