fatti03msp
Contributor
- 03 MSP & 91 RX-7 & 00 1500
Like the title says, just picked up a 03.5 MSP.
Has Sub Frame/undercarriage damage. Why its getting parted out plus it has a Certificate of Destruction Title too
Ill be putting together a parts list soon, and the car will be getting stripped next thursday on 9/20
Didnt look over the car yet, so not sure if all the parts are in great shape.
Only aftermarket thing is they cut off the stock muffler and welded in a new pipe with a magnaflow tip... ******* stupid IMO stock muffler looks way better.
PICTURES OF THE ITEMS I HAVE FOR SALE!!!!
PRICE LIST!!!!!!!!!!
Rear Bumper - 22v Silver - 80
03.5 Rear Lip - 22v Silver - 175
03.5 Wing - 200
03.5 MSP Cluster - 100
03.5 Mazdaspeed Pedals - 50 Has a crack in pedal but not coming apart
Radio Surround - 50
Factory Fuel Rail and Injectors - 50
Window Switch Bezels - 40
Side Mirrors - 40 a piece
03.5 Seats All Four - 400
OEM 22v Silver Hood - 7
Radio Pocket w/ bracket - 50
Black Door Panels - 175 for all four
Black Center Console w/ lid - 75
3rd brake light delete - 40
HVAC Controls - 35
MSP Crash Bar w/ Foam - 150
MSP Axles - 225 for both - 150 each
MSP Oil Cooler - 150
MSP RB Sway Bars - 175 for both 100 a piece
Starter - 30
MSP Right/Passenger TailLight - 40 - Has some scratches
MSP Tail Light Set - 100
EGR Valve - 40
Throttle Body - 30
MAF - 50
MSP Black Carpet - 75
Intake Manifold - 75
SU Front Motor Mount - 65
Starter - 25
Black Seats Belts (Front Female Connectors not included) 125
Window Switch covers (Will Need To Be Painted) 30
Factory Fuel Pump Assembly - 50
Cup Holder - 40
OEM Front Motor Mount - 25
MSP Shifter - 65
MSP LSD Transmission - 650
Complete 5 Lug Swap w/ MSP Brakes-All Rear Bars and E Brake Cables - 500
Doors - include glass and window motor - 50 a peice
Dip Stick - 10
Sony Radio 40
Glove Box - 40
MSP Steering Wheel - 30 Not in the best shape
22v Trunk Lock Cover - 20
MSP Door Sills - 80
Cargo Net w/ Hardware - 60
MSP Tweeter Sail Panels/Mirror Triangles - 50
Butterfly acutators - 40
Batter to starter Harness - 50
Throttle Body - 55 Have 3 of them
Hood Hinges - 15
Intake Cam - 50
Spare Tires - 35
03 FSDE 2.0 Head - 300
thermostat Housing - 40
MSP Valve Cover Has the Pegs to mount the engine cover - 100
Crank Pulley - 20
Timing Belt Sprocket - 20
Shifter Linkage - 75
Power Steering and Alternaotr Bracket - 25
Water Pump Pully - 40
Crank Sensor - 50
Tensioners - 20
Cam Gears - 25
Coolant Tank - 25
Crank - 250
Turbo Setup - Small Crack in manifold, Easy Fix. 600 with ECU 500 With out
MSP AC Condensor - 50
MSP Radiator - 50 Has some gunk on it
MSP OEM Intercooler - 20 Has gunk on it too
AC Compressor - 40
AC Compressor Bracket - 15
Power Steering Pump - 40
Water Pump - 25
Regular Protege Bumper - 65
22v Trunk Lid - 50
Muffler Deleted Axle back with Magnaflow tip - 20
Kenwood rear deck lid triangles - 15
MSP Trunk Sub Enclosure with amp and sub Not factory kenwood sub - 200
MSP Kenwood Door Speakers - 20 Each
Driver Air Bag - 60
03.5 MSP Shift Knob - 60
MSP/P5 Sideskirts - 175
OEM Strut Bar w/ Bracketes - 85
03.5 Wing - 200
Radio Surround - 50
HVAC Controls - 35
Starter - 30
EGR Valve - 40
Throttle Body - 30
MAF - 50
Starter - 25
Cup Holder - 40
MSP Shifter - 65
Dip Stick - 10
Sony Radio 40
Glove Box - 40
MSP Door Sills - 80
Hood Hinges - 15
Intake Cam - 50
Spare Tires - 35
Crank Pulley - 20
Crank Sensor - 50
Tensioners - 20
Cam Gears - 25
Coolant Tank - 25
Crank - 250
AC Compressor - 40
Water Pump - 25
22v Trunk Lid - 50
Driver Air Bag - 60
