CorkSport.com is MAZDA PERFORMANCE!
Page 2 of 13 FirstFirst 123412 ... LastLast
Results 16 to 30 of 191
Thread: How-to: Permanently fix the "no A/C on fan speed 2/3" problem
  1. #16
    Meow HatchKitten's Avatar
    02 Mazda Protege5
    Join Date
    Dec 2009
    Location
    Farmingdale, NY
    Posts
    380
    This is awesome...my fans just started to give me a headache. Added to my to-do list! Awesome write up too!
    02'Protege5: Chester
    JDM_Pro5: Hell yeah, I have mad respect for you. Just watch, he will change his to "4EVRALNE" and next year you will have "LIKABOSS"
  2. #17
    Registered Member
    Join Date
    Sep 2009
    Location
    Montreal, Quebec
    Posts
    2,623
    Quote Originally Posted by pasadena_commut View Post
    Some folks claim that these sorts of connectors are not a good idea for cars. They think that the constant vibration of normal driving causes wear at the wire/metal contact, which can eventually result in the contact failing, or even the tapped wire being cut (worn through). I don't know if this is a real worry or not, but just to be safe I soldered and shrink wrapped all the connections on my fix.
    That's a very good point, I just used it because of the novelty of using one of those connectors. If I were doing it on someone else's car I'd crimp it or solder it properly.
  3. #18
    Registered Member
    2002 Protege5
    Join Date
    Dec 2007
    Location
    Decatur IL
    Posts
    698
    Cool! I don't have my diagram handy. Remind me what this is doing? Is it just ensuring that the compressor sense wire sees ground in every ON position?
    02 Protege5 - Vivid Yellow - 245K mi
    flywheel, clutch, UR pulley, Injen, OBX, MagnaFlow, Hella fogs, Pioneer head, sub, & 6x9s. On my 7th Mazda!
  4. #19
    Registered Member
    Join Date
    Sep 2009
    Location
    Montreal, Quebec
    Posts
    2,623
    Quote Originally Posted by RABID_MP5 View Post
    Pretty much, it makes sure that the sense wire is at less than 1.1V when the fan is on, for a full explanation click here.
  5. #20
    Registered Member north42g's Avatar
    Mazda Protege5
    Join Date
    Jul 2010
    Location
    Central Massachusetts
    Posts
    263
    Nice Job. I'm going to absolutely try it out this weekend.
    Great write up, very simple and straight forward instructions. Good work.
    2002 PR5 2.0L -Daily
    2003 Jetta 2.0L - Family car
    1994 SC-1 1.9L- Winter Beater
    1998 Ranger 3.0L- 4WD, Gota have it
    1969 Classic Bronco 5.0L - running project
  6. #21
    Wiggity-Wack-O-Tack njaremka's Avatar
    Donated: $0.61
    2011 MX5 GT
    Join Date
    Nov 2001
    Location
    Glastonbury, CT
    Posts
    6,900
    AWESOME!! i'm going to try this out this weekend. hopefully, i'll be able to use my AC again...
    Nik
    2012 Mini S Clubman
    Previous:
    2011 Black MX-5 GT
    2001 Black Mica Protege ES 2.0
  7. #22
    Registered Member OGLaughtzalotzz's Avatar
    Donated: $5
    2002 Mazda Protege5
    Join Date
    May 2011
    Location
    Newark, NJ
    Posts
    347
    picked up everything i'll need to do this. Local radio shack had 470 resistor and 220. is the 220 ok to use?
    Quote Originally Posted by bazooka joe View Post
    in the NE rust is a color!
    Fuelly
    Fuelly
  8. #23
    Registered Member
    Join Date
    Sep 2009
    Location
    Montreal, Quebec
    Posts
    2,623
    Quote Originally Posted by OGLaughtzalotzz View Post
    Yup, 220 is fine.
  9. #24
    Donated: $5
    2002 Mazda Protege5
    Join Date
    May 2011
    Location
    Newark, NJ
    Posts
    347
    good deal...first time soldering WOOT WOOT!!!!
  10. #25
    Donated: $5
    2002 Mazda Protege5
    Join Date
    May 2011
    Location
    Newark, NJ
    Posts
    347
    So just got done and now speed 1 no work
  11. #26
    Asian Persuasion <>< Hank3's Avatar
    Contributor
    2010 Mazda5 GT | 2014 Kia Soul !
    Join Date
    Oct 2002
    Location
    Tallahassee, FL
    Posts
    4,649
    Quote Originally Posted by oglaughtzalotzz View Post
    so just got done and now speed 1 no work
    doh!!!
  12. #27
    Donated: $5
    2002 Mazda Protege5
    Join Date
    May 2011
    Location
    Newark, NJ
    Posts
    347
    i know...and it's like the blower doesnt turn on at speed 1!!!
  13. #28
    Registered Member
    Join Date
    Sep 2009
    Location
    Montreal, Quebec
    Posts
    2,623
    Sounds like you cut the wrong blue/yellow wire.
    Have a good look at the pictures (you can actually see both of them), you want the wire that's part of the black climate control connector, NOT the white fan speed switch connector.
  14. #29
    Donated: $5
    2002 Mazda Protege5
    Join Date
    May 2011
    Location
    Newark, NJ
    Posts
    347
  15. #30
    Donated: $5
    2002 Mazda Protege5
    Join Date
    May 2011
    Location
    Newark, NJ
    Posts
    347
    ^x2 now fixed it up fans worked for a hot second and now no speeds work
Similar Threads
  1. Front wiper "intermittent speed" no longer works
    By slavrenz in forum Protege5
    Last Post: 04-14-2010, 12:32 AM
  2. 2007 Mazda5 "sways" running over bumps at highway speed
    By ohaegs5 in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 02-06-2010, 05:44 PM
  3. 2004 Mazda3 "S" Sedan 5-speed FOR SALE!
    By YouFailMe77 in forum Completed Transactions
    Last Post: 12-13-2004, 01:42 AM
  4. Replies: 35
    Last Post: 09-28-2004, 02:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
