Made in USA and Free Shipping on all orders shipped inside the US.
Page 13 of 13 FirstFirst ... 3111213
Results 181 to 191 of 191
Thread: How-to: Permanently fix the "no A/C on fan speed 2/3" problem
  1. #181
    Registered Member grffn's Avatar
    Donated: $8.08
    '02 P5
    Join Date
    Jan 2017
    Location
    Hawaii
    Posts
    264
    Quote Originally Posted by kdsmith7 View Post
    Is anybody in the Philadelphia area interested in performing this fix on my 2003 Protege for $200??
    My wife has had enough of the AC only working intermittently and I'm going to have to move on from my beloved Mazda if I cannot get it fixed. I was able to pull out the radio and start poking around, but I'm really not sure what I'm doing so I didn't get much further than that.
    Please let me know if interested!!
    $200!? Jeez. I thought this guide would be detailed enough for nearly anybody to do.
    If you still have no idea how to do it, why not buy what's needed (listed) and take it to a shop and have them do it for a mere fraction of the price? Just show them this guide.
  2. #182
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    363
    Quote Originally Posted by grffn View Post
    Most shops probably wouldn't do this because they wouldn't want the liability for modifying something electrical in the car.
    It's pretty straight forward, only takes about 10 minutes to do it. It's worth giving it a try yourself, just take your time and follow the pictures. the only thing you need to do is remove the radio, you can access everything you need from there. I would pull the fan switch connector out while you're there though and make sure it's not melted.
  3. #183
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    577
    I did this trick and it didn't work for me so I just soldered on connectors then put on longer wires so it wasn't tugging on the sensor.
  4. #184
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    577
    A quick photo of what it looks like
    Still works a year later.
  5. #185
    Registered Member
    Join Date
    May 2019
    Posts
    2
    Quote Originally Posted by pb4ugotobed View Post
    I'm happy to say that I attempted this today and it seems like it worked! Thanks for the encouragement and of course the initial very-clear, very helpful instructions!
  6. #186
    Registered Member
    2002 Mazda Protege5
    Join Date
    Dec 2013
    Location
    Bowling Green, KY
    Posts
    77
    I am going to give this a try this weekend or next week. I tried the trick where you cut the black housing to expose the male contacts on the fan switch and connected/soldered the wires and it didn't change anything :/ (Still issues with fan speed 2 and 3). Living in Florida this AC issue can be a real buzz kill when driving my car.
  7. #187
    Registered Member
    2002 Mazda Protege5
    Join Date
    Dec 2013
    Location
    Bowling Green, KY
    Posts
    77
    Kdsmith7, I am happy to see a recent post where this worked. I am going to try it now myself.
  8. #188
    Registered Member
    Mazda, Protege5
    Join Date
    Dec 2016
    Location
    Brooklyn
    Posts
    25
    Quote Originally Posted by SlowturboP5 View Post
    Fixed it. I spliced into the wrong blue/yellow wire. But to be honest the directions should've been more clear. To clear things up for people that'll do this in the future, there are 2 blue/yellow wires in the vicinity. The 1 that you immediately see after removing the stereo is coming from the white plug(fan switch). This is not the right one. You have to splice into the blue/yellow wire coming from the black plug that is under the white plug. lol
    Thank you for pointing this out. Made the same mistake as you and was going to live without fan speed 1!!!
    The most difficult part was getting the old radio out, had to get my head down by the floormats to see where my homemade removal tool was going. Decided to upgrade to a bluetooth receiver once i got it out.
    I would also suggest not "splicing" into the ground wire as mine became messy... just find ground elsewhere...
  9. #189
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    77
    i don't know if this is an obvious question, but wouldn't it be easier to just buy a new fan switch? or just clean the old one as pcb mentioned? my AC has stopped working on 3 and i can still get it to work on 2 if I "wiggle" the switch a bit. 1 and 4 work fine. I'm not too keen on doing modifications to electrical wiring, don't want to create a short or a bigger problem lol
  10. #190
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,100
    Apparently, late model P5's had a redesigned fan switch.
    It was a little beefier and could handle more heat and current.
    I assume a replacement fan switch would be the newer design.
    The Diagram Dude
  11. #191
    Registered Member P5freek's Avatar
    2002 Protege5
    Join Date
    Aug 2013
    Location
    Oregon
    Posts
    97
    Sad im only doing this mod now that im selling my mazda lol. fan speed 3 is the best
Similar Threads
  1. Front wiper "intermittent speed" no longer works
    By slavrenz in forum Protege5
    Last Post: 04-14-2010, 12:32 AM
  2. 2007 Mazda5 "sways" running over bumps at highway speed
    By ohaegs5 in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 02-06-2010, 05:44 PM
  3. 2004 Mazda3 "S" Sedan 5-speed FOR SALE!
    By YouFailMe77 in forum Completed Transactions
    Last Post: 12-13-2004, 01:42 AM
  4. Replies: 35
    Last Post: 09-28-2004, 02:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
