Alright, so check this out. Yes I am a new owner of a standard transmission (5 speed Mazda3, 2010). It is my first standard, but I learned very quickly, I don't ride the clutch and I also don't drive it very hard. Here is my problem:
Car: 25k miles, 2 owners (one before me), and the clutch needs to be replaced. Dealership wants $800 just to DIAGNOSE the problem, not including labor and parts to install, they refuse to do anything under warranty as "clutch is a wear and tear item".
When I have the clutch to the floor, sometimes when I shift from neutral to first gear (or any gear) it will stop half way. Now if I continue to keep a little bit of pressure (maybe a half pound or so) it will eventually "work its way into gear". With reverse, it's a little different, when I'm at a stop and I put it into reverse, sometimes it won't go all the way into gear. If I let the clutch up maybe 1 inch from the floor (if that), it will pop right into reverse.
Now after doing a bunch of reasearch, I've noticed people having very similar problems to me. The stock clutch is very weak along with the pressure plate (now that is just my conclusion), please let me know if that is just a normal "standard" transmission thing or if it is something I need to get replaced.
Now my question is, would it be worth replacing the clutch with a $600 aftermarket clutch (I know mechanics who will do this for me), or should I stick with OEM, I just don't want to have this same issue happen again. If you recommend aftermarket, could I get some links and some ideas. I found one for a 2010 2.3l turbo mazda3, will that work with my car?
