CorkSport.com is MAZDA PERFORMANCE!
Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
Thread: Have you DIY'd your front sway bar bushings??
  1. #31
    Registered Member
    Mazda 5 Exclusive 2.0L petrol 6MT
    Join Date
    Aug 2013
    Location
    Italy
    Posts
    34
    Keep in mind. Passenger side for jinjur is drive side in America.
  2. #32
    Registered Member
    Mazda5, 2007
    Join Date
    Nov 2011
    Location
    Brampton
    Posts
    3
    Glad I found this thread because even the back bushings bolts were terrible to remove and there was plenty of access. The front bushings seemed impossible when I was under the Mazda 5. Will give accessing from the wheel well a try. Kudos to the original poster.
  3. #33
    Registered Member
    Mazda5, 2007
    Join Date
    Nov 2011
    Location
    Brampton
    Posts
    3
    Two sway bar bushing bracket bolts snapped when I tried to replace the bushings. The locations are rear driver side and front passenger holes. Accessing the bolts from the wheel wells was a struggle. Had to extend 1/2 inch socket with a pipe and unscrew one ratchet click at a time. They snapped when the entire exposed rusted portion contacted all the hole threads. I guess friction was too great.
    Now there is a bigger problem of removing the Gr 8 bolts stuck in the subframe. Tried to drill a hole in the subframe directly below the bolt to reach it but the small 1/16 drill bit didn't make a dent. Any suggestions.
  4. #34
    Registered Member
    2010 Mazda 5 Sport
    Join Date
    May 2019
    Posts
    70
    I just did this job when I redid the front struts on a 2010 Mazda 5. That front driver's side bolt is definitely a PITA to get to. From the driver's side wheel well, I used a box end wrench over it with a 12" cheater pipe and got her free. Also from the wheel well, I used a few extensions with 2 swivels on a ratchet to work her out. Thank god for NC cars and no rust.
    If I was to do it again...I WOULD REMOVE THE BATTERY AND BATTERY BOX.
    I had to remove the box because I dropped a strut bolt behind it. Looking down in the engine bay...It looked like I should be able to get at it easily from the top.
    I also removed that skinny skid plate that crosses the exhaust tunnel...this give you more room for your arm working underneath.
    Everything else, I worked blindly but it's pretty straight forward.
    After the struts (KYB) were swapped in and the sway bar bushings replaced...ZERO clunking up front.
    Thanks for all the tips guys.
    -Mike
  5. #35
    Registered Member
    Mazda5, 2007
    Join Date
    Nov 2011
    Location
    Brampton
    Posts
    3
    To finish the story, I drilled a 1.5" hole with a Lenox holesaw in the subframe below the broken bolts. Next I drilled out the bolts with some cobalt drill bits. Then switched to a 1/2" bolt and nut after the bushing change. No more annoying clunk.
Similar Threads
  1. FS: OEM MS3 Front and Rear Sway Bars, Bushings and Front Endlinks.
    By zoomzoomMSP in forum Mazda3 For Sale
    Last Post: 02-20-2012, 11:36 AM
  2. FS: Front End links, front and rear sway bar bushings
    By jdwk in forum Mazda Protege For Sale
    Last Post: 04-24-2011, 03:37 AM
  3. Front Sway Bar Inner Bushings
    By 91Protege in forum Mazdaspeed Protege
    Last Post: 04-18-2011, 09:31 PM
  4. Is it the front sway bar bushings?
    By ohioan in forum Mazdaspeed3
    Last Post: 06-08-2010, 12:16 PM
  5. Front Sway Bushings
    By livelyjay in forum Mazdaspeed Protege
    Last Post: 04-19-2010, 08:42 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
