- Mazdaspeed6
I've never used them for ATX fluid, because I've never owned an ATX before the CX-5. XD
But, yes, supposedly Blackstone performs UOA on ATF.
Did this job last night with mazda FZ fluid. Took 3.5 qts. The old fluid was definitely a darker reddish brown compared to the clear/blue tint FZ fluid, but the old 60k mileage wasn't full of particles and sludge or anything..looked pretty clean still just off color. I'll probably do this every 50k or so for peace of mind, its only $50 and an hour or so.
I test products for a certain fluid/additive company and I will be using our product and flush machine to replace my ATF on my 14 CX-5 when I hit about 25k. We recommend 30k here, but since I work for the company, why not do it sooner? I've been taught while working in dealerships to only drain and fill transmissions (Honda) and other places (BMW) with "lifetime" fluids. And I've seen many transmissions fail and nasty fluid is what came out of them. We have fittings to hook up to nearly every vehicle out there. After seeing tests done on many different vehicles, I'll be doing a fluid replacement instead of a drain&fill on my vehicles.
It doesn't make any sense to drain and fill since you're only getting about 1/3 to 1/2 of the fluid out. That new fluid mixes with the old that isn't removed and isn't new fluid anymore.
What was the cost with the CX-5?I've asked multiple transmission shops a couple of years ago when I wanted to have my high mileage BMW lifetime ATF flushed. Nobody was willing to do it- as they did not want to be held responsible for damage. Nobody, not even BMW dealerships. Only 1 transmission shop was willing to do a BMW flush BUT only if it was under 50k miles. Mine was at 100,000k miles. The lesson being that cars with lifetime ATF should be changed under 50k miles. If it has not been changed after that point you're actually better off leaving it as is because the fluid contains "valuable" metal shavings. I know its weird but that's BMW's explanation to me at least.
That said my Mazda dealership used the flush then fill method for the CX-5.
So you performed this maintenance at 60k? Would you reckon a change at even higher mileage acceptable?
Also, yes, I killed an Infiniti G20 transmission by having the Infiniti dealer drop the pan, replace the filters and fluid. It died soon thereafter with failure to shift, multiple tq converter lock-up codes, etc. 110k miles. Service done around 108.
