Mazda of the Month - VOTE NOW for May!
VOTE NOW for May!
  • Total voters
    53
  • Poll closed .
Status
Not open for further replies.
Antoine
Administrator
Welcome to the Official Mazdas247.com "Mazda of the Month" Contest!
* The MOTM is OPEN to ALL Mazdas! *
Please note the following rules & guidelines.
Your cooperation and participation would be greatly appreciated, thank you.
ENTRY RULES
* You must own the Mazda you are entering into the contest
* Any form of photo/image manipulation is not allowed except for adjusting and enhancing image color, contrast, tone and levels etc
* If you wish to enter two or more times in a row, you will need all new photos of your Mazda for each consecutive month entered
* If you become a MOTM winner, you may not enter the same Mazda again until at least 12 Months after the month you had won. However, if you own several Mazdas, you are welcome to enter those as well * Each Member may NOT enter more than one Mazda per MOTM contest * Previous MOTM winners who wish to enter again (after 12 months) must enter with all new photos of their winning Mazda
* Once you have entered (posted) your Mazda, you may not withdraw from the contest
* The MOTM contest & rules are subject to change in order to maintain a fair & fun environment for the Mazdas247.com Community
ENTRY REQUIREMENTS
* Each contestant must submit three single high-quality high-resolution images of their Mazda. One image must be of the exterior, another the engine bay and finally an interior shot. Compilation style shots (multiple images within a single image or picture size frame) are NOT ALLOWED!
Format
1. Username
2. Name
3. Model name + (Year)
4. ONLY 3 Images (one exterior + one engine bay + one interior shot) NO ATTACHMENTS PLEASE!
5. "Mod" List *Please make your list CLEAR & CONCISE!
Entry Tips
* Wash & Wax
* Clean your interior
* Clean your engine bay
* Choose an interesting location
* Choose a well lit location for photos
* Make sure your interior shot is clear and detailed
* Make sure your engine bay shot is clear and detailed
Example (Obviously, this is NOT my Mazda but for the sake of an interesting example):
Antoine
Antoine *
Mazda 767B (1989)
Performance Mods:
600hp 4Rotor
Exterior Mods:
Aero tuned for the track
Interior Mods:
ALL BUSINESS
Stereo Mods:
4Rotor
Awards Won:
Second in awesomeness only to the 787B
Recognition:
Raced at Le Mans...Helped lay the groundwork for the 787B which won Le Mans in 1991.
PRIZES
* A Mazdas247 T-Shirt and a pair of Mazdas247 Decals!
* Your Mazda showcased on the Mazdas247 Home Page!
* 5% off any Speedcircuit.net purchase made that month!
VOTING RULES
* All voters must have a postcount minimum of a 100 posts. The only exception to this rule is for MOTM participants who are also new members
* There is NO tolerance for PERSONAL CAMPAIGNING threads, posts, private messages (PMs), images or links (including signature and or image links). The creation of such ANYWHERE on or off the Internet including Mazdas247.com will result in immediate disqualification *If you are disqualified, your entry & poll listing WILL remain but your votes will be removed. Everyone will see that you broke the MOTM rules
* Creating GENERAL "Vote for the MOTM" threads and links is allowed and encouraged
GOOD LUCK AND HAVE FUN!
2003.5_MSP
Patrick
Mazdaspeed Protege 2003.5
Performance MODS:
POPE DP
custom 3" exhaust
Drilled/Slotted Rotors
Exterior MODS:
S204 lip lip
ISport CF Rear window Spoiler
Maxspeed Lowering Springs
Debadged Trunk
DIY Retrofitted 8k HID W/ audi style LEDS
Smoked Side repeaters
Smoked Reverse/Rear Turn Signals
Interior MODS:
Trim pieces painted black
Glowshift under radio bezel/wrapped in black plaid
Glowshift Boost/Vac gauge
Glowshift Exhaust temp gauge
Glowshift Oil pressure gauge
Joka1
Rob McCord
2002 Mazda Protege ES-T
Performance Mods:
-Fully built motor at 8.1 compression- Pauter Rods/ Wiesco Pistons/ Bored .20 over/ ARP Main Bolts/ Clevete Bearings
-T3/T04 Turbo
-Perrin Intercooler
-Turbo XS Rfl Bov
-Tial Wastegate 8 PSI Spring
-Mpi Tuner EMS w/Turbo Module
-NX N-tercooler system
-550 Injectors
-2 Extra 440 Injectors
-Ceramic Coated PG Intake Manifold
-Custom ADJ Cam Gears
-MAM Tubular Manifold Ceramic Coated
-Custom 3" TurboBack Exhaust w/ Magnaflow Muffler
-Greddy Profec B EBC
-Exedy Stage 2 Clutch
-Fidanza Flywheel
-AWR Deep Sunk Baffled Oil Pan
-Greddy Full Auto Turbo Timer
-Custom Turbo Pipes
-Hose Technique Turbo Couplers
-Weapon-R Engine Dampner
-AWR Front/Rear Motor Mount
-JIC A2 Coilovers
-KMR Lower Tie Bar
-GT Spec Front Strut Bar
-VTTR 6 Pot BBK
-VTTR Stainless Steel Brake Lines
Engine Apperance Mods:
-Dg Carbon Fiber Engine Cover
-Polished Valve Cover
-Custom Hood Props
-GT Spec Strut Bar (Ends Ceramic Coated/ Middle Black)
-Custom Radiator Shroud
-Hose Techniques Blue/Black Vacuum Line Kits
-Chromed Turbo Compression Housing
-Blue Top Optima Battery
-Cut Valve Cover to Show Cam Gears
-Blue Radiator Overflow Can
-Custom colormatched show washers
-Custom Optima Battery Box
-Aero-Catch Flush mount hoodpins
-Hella Supertones
-Speedcircuit Thermostat Outlet Kit
-Apexi Diverter Plate
Exterior Mods:
-Full Msp Front End Conversion
-DG Front Lip
-Buddy Club 2 Side Skirts
-Buddy Club 2 Rear Bumper
-VIS C/F Hood Custom Painted
-Vis C/F Trunk Lid
-EVO 8 Spoiler
-DG C/F Grill
-DG C/F mirror covers
-Tinted Sidemarkers
-Piaa 540 Foglights
-18" Enkei Sesto Rims
-5% Tinted Windows
-JDM Style Headlights
-AAC Bumper Brackets
Interior Mods:
-4 Point AutoPower RollCage
-Reapulstered Backseat W/NX bottle Mounted in the Center
-Autometer Phantom Wideband A/F Guage
-Autometer Phantom Boost Guage
-Autometer Phantom Pryometer
-Autometer Phantom Volt Guage
-Autometer Phantom Oil Pressure Gauge
-Autometer Phantom Tempature Guage
-Autoguage 3 Guage A-Pillar Pod
-Forcefed Modified Steering Wheel Pod
-Forcefed 2 Guage Cluster Surround
-Adj Shiftlight
-Bride ERGO Blue/Black Front Seats
-Sfi Certified 3" 5 Point Racing Harnesses
-Reapulstered Door Panels
-Dyed Headliner
-Nokia Blue Shif Knob
-Nokia blue Racing Pedals
-Sparko Black Suede/Leather Steering Wheel
-Blue Led's Under Each Seat
-C/F Covered NX Arming Switched
-DG C/F Doorsills
-Corksport C/F Guage Surround Overlays
-Custom Molded Stereo Surround
Stereo Mods:
-Compustar Alarm
-Kenwood Indash 7" Touchscreen
-7.2" Rear TV
-Audiobahn Immortal 10
-Phoenix Gold Amp
-JL Interior Speakers
2011 Awards won:
-May 11: Mazdas247 ROTM
-Jun 11: Forum Fest- Best Mazda
-Aug 11: Remix Car Show-Hottest Mazda
-Aug 11: Remix Car Show-Best Display 3rd Place
-Sep 11: MazdasNW End of Summer Bash @ Corksport- Best Display
-Sep 11: MazdasNW End of Summer Bash @ Corksport- Most Carbon Fiber
2Nine
Ian
08 Mazdaspeed 3
Performance Mods:
COBB SRI
Turbo-Smart 50/50 bpv
3" SU Testpipe
RES Delete
Exterior:
Yellow Tinted Fogs
Debadged
Buddy Club P1f 18x7.5
Raceland Coilover's (rolled rear)
Silverspeed2015
Leo Chernisky
2007 Mazdaspeed6 GT
INTERIOR ?
ENGINE BAY ?
MODS ?
STRICK-
Steve
07' True Red Mazdaspeed3 GT
ENGINE BAY/DRIVETRAIN/PERFORMANCE
SURE Aeros intake
SURE Sidewinder turbo inlet
SURE shortcut short shift plate
SURE countershift weight
SURE t.I.g.
SURE torq R3 rear engine mount
SURE Return recirc tube
$treetunit passenger side engine mount
$treetunit 3" testpipe
$treetunit billet washer fluid cap
$treetunit billet coolant cap
$treetunit "blackout edition" T.S. blow off valve
Denso iridium itv24 spark plugs
Protege garage fmic pipe kit
CX racing fmic core
PnPed intake manifold w/ VTCS delete
Weapon R oil catch can
Powdercoated valve cover,intake manifold & misc. other accessories
Redline hood lifts
INTERIOR
SONY 7" dvd/nav headunit w/ ipod integration
4 SONY 6.5" moniters (headrest,hatch)
SONY 6.5" components (front doors)
SONY 6.5" 3 ways (rear doors)
2 SONY 12" subs
2 SONY monoblock sub amps
1 SONY 4 channel midrange amp
Custom enclosure & panels
JL wiring & distribution
Redline goods shift boot & armrest covers
Red l.e.d. dome,map,hatch & floor lighting
Prosport boost gauge w/ custom vent pod
TWM Short shifter
$treetunit billet shifter bushings
3m carbon fiber wrapped interior trim
painted dash strip(true red)
WHEEL-TIRE/SUSPENSION/BRAKES
18 x 9 +28f +26r WORK VS-XX (freshly rebuilt)
205/40-18 Yokohama s drive tires
BC racing coilovers
Project Kics r40 revo neochrome lugnuts
EBC redstuff brake pads
EXTERIOR
nextmod carbon fiber RE replica spoiler extension
15% tint all around
50% winshield tint
Blacked out M badges
Yellow laminex fog light overlays
Parts plaza eyelids
Blacked out upper front grill
Autoexe stubby antenna
Autoexe wiper blades
7 Days left......... only 20 votes so far :(. Lets get some more voters!
voted, joka if you didn't have that wing I think yours would take the cake for me. IMO
Its all good. I went W/O a spoiler for a few years........ It was a nice look then I decided to change it up. I like this new look for now but I may get bored and try the new STI spoiler ;)........
Rob
BTW bumping for more voters........... Pick your favorite car and cast the vote!!
Joka got mine. The custom mods in the engine bay (battery box) tilted me in that direction but the brunette hood prop with Strick's engine bay almost swayed to the GENDONE. Both cars are very clean
Thanks brotha! I originally put my submission in with a pic of them installed. But it was just a driveway pic though. Thanks for everyone that's voted so far this month. Myself and all the entries appreciate it greatly.
Couple of hours left and it seems we have a tie ;)
Lets get a last minute push with more votes................ As stated above thanks to all the voters so far!!
Rob
yep, lots of protege people showing love. wish some speed people would come through too :) your getting a last minute push hahaha
good luck to ya. its a close one
JOKA1
I don't understand the "Show and Go" thing but There is an obvious level of work there that only a handful of people on the forum can understand..
You have my Vote HANDS DOWN and I know there are others on the forum who agree with me.
Thanks Lawrence....lol.
Close one this month. It looks like it ended up 18 to 17 eligable votes this time around. Thanks to everyone that took the time to vote and everyone that entered. Its you all that keep this thing going and strong. :)
JOKA1
Thanks Brian..... I love showing and do it alot but the drive to and from the shows are normally the most fun ;)
Rob
Once again thanks to everyone who voted. I just realized I forgot to vote :(
I have a boxer in labor so I did not watch the final votes............. I never voted and I knew As of 2 days ago I had 2 unqualified votes and strict had 1........
Best of luck to all! All were nice cars!!
Rob
Status
