Page 3 of 23 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 333
Thread: CX-5 Oil Change with Filter
  1. #31
    Registered Member Jonesey's Avatar
    CX-5 6MT
    Join Date
    May 2012
    Location
    NJ
    Posts
    138
    Does anyone know a part number for an oil filter? The OP mentioned 6607 (Amazon references 6607) or that he used 7317 but does anyone know the filter to use?
  2. #32
    Registered Member jp1450's Avatar
    Join Date
    Apr 2007
    Posts
    18
    The Mazda part number is PE01-14-302
    jp1450
    2013 CX-5 GT AWD
    2012 Mazda 3i
    2007 Mazda 3s
    And lovin' all three of 'em!
  3. #33
    CX-5 6MT
    Join Date
    May 2012
    Location
    NJ
    Posts
    138
    Thanks jp - that'll help. It looks like a lot of filters fit
  4. #34
    Join Date
    Apr 2007
    Posts
    18
    Quote Originally Posted by Jonesey View Post
    No problem. Glad to help. I found the OEM filters from the dealer to be fairly reasonable ($7.25), so I am sticking with them for now.
  5. #35
    Registered Member under200's Avatar
    2013 Mazda CX-5 Touring
    Join Date
    Aug 2012
    Location
    IL
    Posts
    86
    Curious, not due for an oil change yet but is their any special reset on the computer to set after you change your oil?
    My Toyota has some series that included turning the key to acc and pressing the gas 3 times. This reset the computer service light countdown. Basically ever x amount of miles the oil change or service light would come on to let you know to change it, of course this trick was not in the manual but only on forums. Guess the dealers like scaring people into the shop.
  6. #36
    Registered Member
    2013 CX-5 Touring
    Join Date
    Sep 2012
    Location
    Houston, TX
    Posts
    381
    I don't think that there is a service light or other indicator on the CX-5.
  7. #37
    Zoom Zoom Baby! KnurledNut's Avatar
    Join Date
    Oct 2012
    Location
    Sonova Beach
    Posts
    100
    Quote Originally Posted by gverrault View Post
    Anyone know if this would work on the CX-5? I can't see why not particularly if you oriented it so that the lever was facing down.
    http://www.amazon.com/Fumoto-F-106N-...I21M2J2HKZRDWV
    I've used Fumoto drain valves on my last 3 vehicles. I like performing a hot oil change and not getting burned in the process. An adapter is needed to clear the recessed port on the CX-5.
    http://www.quickoildrainvalve.com/se...ts.asp?cat=307
  8. #38
    Registered Member
    03 P5, 13 CX5
    Join Date
    Sep 2004
    Location
    behind you
    Posts
    2,956
    good link. thank you.
  9. #39
    Join Date
    Oct 2012
    Location
    Sonova Beach
    Posts
    100
    Does anyone know what size hex nut is needed to remove the drain plug? I don't if I have one that big.
  10. #40
    MoMo MikeM.'s Avatar
    2013 Mazda CX-5 Touring AWD 2.0L
    Join Date
    Aug 2012
    Location
    NW Washington State, USA
    Posts
    3,970
    The problem with drain valves is they are prone to breaking off from hitting road debris and when that happens your engine oil drains without notice. That's why oil drain nuts are flush to the oil pan (so they do not apply leverage to the oil pan in the event of impact or grounding).
    How hard is it to remove a plug during oil change?
  11. #41
    Registered Member
    Red 2016 CX-5 GT Teck Isense
    Join Date
    Mar 2012
    Location
    GA
    Posts
    983
    Quote Originally Posted by MikeM. View Post
    If you look at the pictures attached to the first post on this thread, the drain plug is a few inches above the plastic belly pan under the car. It is unlikely that road debris would break it off without you knowing that you hit something and better check for damage.
    It is not hard to remove a plug but it is also easy to get oil all over you and the valve with a nipple for a tube to control the drain of the oil is appealing.
  12. #42
    Join Date
    Oct 2012
    Location
    Sonova Beach
    Posts
    100
    I've used these valves on my past 3 vehicles (Tacoma 4x4, Subaru Forester, F-150 4x4). Road or trail debris was never an issue and I routinely travel off-road.
    I use these valves because of their ability to allow a hot oil change without getting burned and ease of use. I agree it's not hard to wrench a drain plug but how many times have we spilled oil or burned ourselves?
  13. #43
    Join Date
    Aug 2012
    Location
    Posts
    3,970
    Quote Originally Posted by KnurledNut View Post
    Never.
    I put the drain pan under the drain and let the nut fall into the pan. Never had a problem. But if I did it would be a minor inconvenience compared to shearing off a drain spout while driving.
  14. #44
    Registered Member
    CX5 Sport MT
    Join Date
    Jun 2012
    Location
    Seacoast NH
    Posts
    187
    I believe it's an 8mm, but it's been a month since I did mine. I had the size in my Hex socket set.
  15. #45
    Registered Member
    Mazda CX-5
    Join Date
    Nov 2012
    Location
    WV
    Posts
    2
    Does everybody who do their own changes also change the plug gasket?
Similar Threads
  1. oil change/oil filter
    By Huascar82 in forum Mazda6 Engine & Transmission
    Last Post: 04-03-2007, 10:11 AM
  2. umnitza filter change over
    By tsunami in forum Mazdaspeed3
    Last Post: 11-02-2005, 08:40 PM
  3. oil filter P/N change
    By Sir Nuke in forum Protege5
    Last Post: 05-22-2004, 08:33 PM
  4. i just got my first oil/filter change...
    By NAYo2002 in forum Protege5
    Last Post: 08-23-2003, 06:49 PM
  5. Oil + Filter change
    By cesar350 in forum Protege5
    Last Post: 08-14-2003, 10:47 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
