Page 9 of 9 FirstFirst ... 789
Results 121 to 129 of 129
Thread: Roof Racks
  1. #121
    MoMo MikeM.'s Avatar
    2013 Mazda CX-5 Touring AWD 2.0L
    Join Date
    Aug 2012
    Location
    NW Washington State, USA
    Posts
    3,970
    Quote Originally Posted by Ride92 View Post
    So can anyone get those dimensions for me? I think it's useful info to have. Maybe I should start a new thread.
    I would measure for you if I had the rack to measure. Sorry!
  2. #122
    Registered Member
    CX5 Sport MT
    Join Date
    Jun 2012
    Location
    Seacoast NH
    Posts
    187
    Quote Originally Posted by jKreu View Post
    What's everyone's imput on fitkits that sit on the rain gutter with custom feet and then clip down into the door frame?
    Is this type of rack really that much more limited?
    I want to be able to potentially put kayacks up or snowboards or cargo boxes in the future.
    This kit specifically?
    http://www.rackoutfitters.com/mazda-...of-rack-12-15/
    Advantage to the Clip system is the base system can adapt to a great variety of vehicles. Also the rack will sit further forward on the car so you'll have less chance of interference with kayaks or cargo boxes hitting the hatch. Also faster to take the rack system on and off the car after the initial setup.
    Disadvantage is the potential to mar the paint. I make a point to clean the roof on a regular basis to keep road dust from working it's way under the tower pads. They can also be fussier to fit to the car since they are tested to sit at specific points on the roof. The raised rail attachments and fixed points attachments are easy to setup initially.
    Now regarding the Thule Aeroblade kit you mention, look at the specs, 110 lbs capacity, 27" distance from the front to the rear bars. That's fine for snowboards but close to marginal for kayaks. Most kayaks are 50-60 lbs, and you want the longest barspread possible, 24" is considered the minimum for kayaks/canoes/paddleboards.
    A Yakima Q tower system that "clips" onto the CX5 has a 125lb weight limit and is 32" between the bars. Much better scenario for carrying kayaks. Yes with just the bars the Aeroblade will be quieter but once you add mounts to the bars, windnoise will be there no matter what.
    I'm a independent sales rep for Yakima and could go into many other reasons to buy Yakima but for carrying kayaks, barspread and weight capacity are significant specs to look at and compare.
  3. #123
    Registered Member Ride92's Avatar
    2016 Mazda CX-5 GT AWD w/Tech & i-Activesense
    Join Date
    Mar 2009
    Location
    Menomonee Falls WI
    Posts
    1,650
    rjdee, your a rep for Yakima, cool! I am wondering if Yakima has any options for adding the Whispbar system to the CX-5? I'd really like to get the flushbar system for my car and use the attachment points that are under the weather strips in the roof. I'm thinking I could drill a small hole in the weather strip to allow access to the threaded part and use a fit kit to secure it. Do you know if this would possible?
    Just Giver!!!
  4. #124
    Registered Member
    Join Date
    Sep 2014
    Posts
    11
    Quote Originally Posted by rjdee View Post
    I'm looking to place an order today, could you send me a pm with what Yakima has to offer?
    Those are important specs you're right. I am worried about the 27"-28" distance in between crossbars for thule but was told that is average for roofracks.
    Also another concern of mine is the circle cross bars. My issue with them is the belief that most mounting accessories will have a much harder time staying secure on round bar rather than a oval or square bar. I would think that most things will want to tilt forward or backwards because it is round.
  5. #125
    Registered Member dawhoo's Avatar
    CX 5 Touring
    Join Date
    Sep 2013
    Location
    Charleston, SC
    Posts
    65
    They are way louder almost unbearable above 35mph. I would never get the clamps myself.
  6. #126
    Registered Member
    2016 CX-5
    Join Date
    Nov 2008
    Posts
    5
    Has anyone modified their existing roof molding so that they can install a direct mount roof rack. I can purchase the pre drilled moldings for about $70, but if the solid ones can just be drilled out, I'd rather save that money. 2016 cx-5 Sport
    Thanks
  7. #127
    Registered Member
    Mazda CX-5 Granda Touring
    Join Date
    Oct 2017
    Location
    SF Bay Area
    Posts
    9
    I was happy with the Rola fixed mount bars I got for my 2011 Mazda3 hatch, so when I saw the Rola 59767 on sale a few days ago, I ordered it for my CX-5. Should be arriving any day now. Unfortunately it's not fixed point, it uses clips.
    I was going to get the factory rails and cross bars but due to the placement of the crossbars, I can't use my Yakima Skybox 16 on it. I thought about getting another rooftop box, but most that are long enough to fit skis won't fit the factory rails and crossbars. That's why I went with the Rola, but am now having buyer's remorse. Will report back once I get them and install it.
  8. #128
    Registered Member
    CX-5 AWD GT
    Join Date
    Apr 2017
    Location
    Australia
    Posts
    87
    Do these roof racks need rail bars to be fitted on?
    https://www.ebay.com.au/itm/162941557326?ul_noapp=true
  9. #129
    Registered Member
    Join Date
    Sep 2007
    Posts
    7
    I was wondering if someone could measure the bolts used in the stock rail to bolt to the roof. I bought a used set of rails and bars and the dealer did not keep the bolts and mazda does not list the size of them anywhere.. And my dealer can't/won't tell me. Thanks..
    2015 cx5
Similar Threads
  1. WTB Roof Racks
    By funtege5 in forum Completed Transactions
    Last Post: 12-24-2011, 10:37 PM
  2. Roof Racks
    By Mz3Hatch in forum Mazdaspeed3
    Last Post: 08-02-2009, 03:10 PM
  3. Roof Racks
    By New Phase! in forum Mazda3 Lounge
    Last Post: 12-30-2003, 03:57 PM
  4. roof racks
    By eting_pro5 in forum Mazda Protege
    Last Post: 10-13-2003, 08:14 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
