Page 3 of 9 FirstFirst 12345 ... LastLast
Results 31 to 45 of 129
Thread: Roof Racks
  1. #31
    Registered Member
    2013 CX-5 GT
    Join Date
    Apr 2012
    Location
    Georgia
    Posts
    10
    Sorry to double-post, but quick positive shout out for ParkMazdaOEMParts on eBay - just bought rack/rails from them, they shipped within 24 hours, and all for $313. Other stock accessories there for MUCH cheaper than my dealerships here. Dealer I bought from wanted $650 and next closest wanted close to $900 (what a rip). Instructions were included: all you need is a flat-head screwdriver, 10mm socket wrench, a Torx bit for a screwdriver (my el cheapo bit set labeled its size as a "T20" which worked fine but I'm not claming that's "exact fit" for the screw, but awful close, if not), and something to cut the metal/rubber/plastic "gutter guards" that are in your roof now (to make space for the 'feet' of the rack...I used my Dremel but wished I had an appropriate blade on my circular saw). I am very slow at installing such things and I did it all in about 60 minutes, maybe a handful more. Glad I saved hundreds on dealer fees, too, as I see nothing wrong with my installation.
    My instructions were missing a step FWIW as well: didn't mention to screw the 'feet' to the 'arms' of the rack with those crazy screws... but observing all the components provided and adding 2+2 helped fill in the blanks.
  2. #32
    Registered Member
    Pearl White AWD GT w/Tech
    Join Date
    Mar 2012
    Location
    New York City
    Posts
    266
    sounds good thanks for the headsup. Any issues with wind noise now that you have added the rack?
    Quote Originally Posted by Puja McGriddle View Post
  3. #33
    Registered Member
    CX-5 Touring AWD, Tech package, Metro Grey
    Join Date
    Mar 2012
    Location
    Denver, CO
    Posts
    39
    For those that are interested, the Thule US website now lists a fit kit for the CX-5, and.... surprise surprise, it's the same as nearly every other Mazda, including my old 2006 3 hatchback. Thankfully, I kept the rack, and it's a direct fit onto the CX-5. I just had the widen the tower spacing a bit to fit the wider CX-5 roof. The fit kit is number 3069. You'll want to mount each bar on the inner set of mounting points. That is, each corner has two holes for two bolts, which is what the OEM Mazda roof rails require. But the Thule rack only needs one mounting point per corner. So, to ensure your attachments can actually reach from the front bar to the back, use the rear set of mounting points for the front bar and the front set of mounting points for the back bar. This will also ensure your back bar does not hit the shark fin thing. My Rocky Mounts bike tray was just long enough to reach from one bar to the other with a little overhang.
    As for the gutter trim pieces, the Mazda OEM roof rails manual tells you to cut the trim strips to fit. That seems like a bad idea as it would make it easy for dirt to work its way under the roof rack towers, potentially causing rust years down the line. I just drilled holes where the mounting bolts are. It isn't the most elegant solution, but it sure beats getting out your circular saw and risking totally ruining your trim strips. Just mark the holes to drill using a black magic marker on the silver side of the trim pieces.
  4. #34
    Registered Member
    Join Date
    Mar 2012
    Location
    New York City
    Posts
    266
    Mind posting pics?
    Quote Originally Posted by particleman View Post
  5. #35
    Registered Member
    2013 CX-5/Touring/Liquid Silver
    Join Date
    Jun 2012
    Location
    Raleigh, NC Area
    Posts
    3
    Has anyone had trouble getting the OEM roof rails? I couldn't get them with my CX-5 when I purchased it. Apparently, there's some engineering hold on them? The parts person could only tell me that either Mazda is having trouble getting component parts or that they're having trouble with the rails design? I got my vehicle in mid-April and still haven't been able to get the rails. I'll probably be looking at either the Thule or Yakima racks if this keeps up.
    Thanks!
    Mark
  6. #36
    Registered Member Jcanracer's Avatar
    CX5 Sport 6spd
    Join Date
    Jun 2012
    Location
    South Florida
    Posts
    273
    Quote Originally Posted by JTNY View Post
    Mind posting pics?
    looks like it requires the factory rails. $435 msrp and kit comes with aero bars.
  7. #37
    Registered Member
    Join Date
    Mar 2012
    Location
    Denver, CO
    Posts
    39
    Quote Originally Posted by Jcanracer View Post
    Sure, I will post pics tonight. The pic above is not what I have though. I did not get the OEM rails with Thule cross bar. I got Thule towers with Thule cross bars. If you get the Thule towers, there is no need for the OEM rails.
  8. #38
    Registered Member
    Join Date
    Mar 2012
    Location
    Denver, CO
    Posts
    39
    Pictures here: https://picasaweb.google.com/1132053...82/CX5RoofRack
    Took me about an hour. The parts I used are:
    2010 Thule 460 Podium, Fit Kit Brackets = 3069 for Fixed-Point for 06 Mazda 3 hatchback
    Load Bars length 50 inches
    2010 Thule Lock Cylinders
    Total cost (last year) was $336, from ORS Racks. This does not include the bike tray, which I had from a previous car.
  9. #39
    CX5 Sport 6spd
    Join Date
    Jun 2012
    Location
    South Florida
    Posts
    273
    ooooooh I think I like this more.
    I have the removable version of this roof rack that clips to the top of the doorjam. Mine is recycled from my Toyota Matrix, and although I made it fit on the CX5, its not a permanent solution, plus I am afraid of it scratching the paint.
    That bolt that you show in picture #4, did you have to drill into the roof or is there a slot for it under the black plastic strip?
  10. #40
    Registered Member ZuluCX's Avatar
    2018 Mazda CX-5 GT AWD+Tech / SoulRed+ParchmentWhite
    Join Date
    Mar 2012
    Location
    Gatineau, Canada
    Posts
    157
    no the holes are already there beneath the plastic strips, same holes where the grey roof rails attach.
    I personally prefer the grey roof rail solution since it allows the cross bar to be removed, with the other solution you would need something to plug the holes when you remove the rack. But they both look nice.
  11. #41
    CX5 Sport 6spd
    Join Date
    Jun 2012
    Location
    South Florida
    Posts
    273
    Particleman, how is the wind noise and MPG loss with those crossbars permanently attached?
    I think i got -2mpg on the highway with my last roofrack.
  12. #42
    Registered Member
    Join Date
    Mar 2012
    Location
    Denver, CO
    Posts
    39
    It's only been on a few days so I haven't noticed a MPG difference yet. Right now I'm at 32 MPG average (AWD, mostly highway). The wind noise is pretty annoying, and it's not even worth opening the sunroof when there's a bike on the rack because it's so loud. I guess it's the price you pay for a roof rack. Maybe a wind deflector would help? The other solution is to get a hitch rack, but I'm always paranoid about someone rear-ending me and destroying my bikes. Not to mention it makes parallel parking harder.
    Also, ZuluCX is correct that if I removed the rack, the holes I drilled in the plastic strips would be exposed. But I don't plan on ever removing the rack as I'm always either riding bikes in spring/summer/fall or skiing in the winter (benefit of living in Colorado!)
  13. #43
    CX5 Sport 6spd
    Join Date
    Jun 2012
    Location
    South Florida
    Posts
    273
    yes, I remember visiting Colorado last summer and every car (most of which were Subarus) had a roof rack!
    I live in South Florida and go Kayaking once or twice a month, so I am torn about mounting rail + removable crossbars, or a more permanent solution like yours.
    I think the right mix would be the permanent tower and crossbar solution with their aero-bars.
  14. #44
    Registered Member
    CX-5 Touring
    Join Date
    May 2012
    Location
    philadelphia
    Posts
    16
    Confused. I really need a roof rack to carry three bikes, do I go with all MAZDA OEM ? or the mazda rails with Thule 450R Crossroad AeroBlade Base Roof Rack?
  15. #45
    Registered Member
    CX5 Sport MT
    Join Date
    Jun 2012
    Location
    Seacoast NH
    Posts
    187
    Quote Originally Posted by joeatmazda5 View Post
    The Mazda dealer bike mounts are basic Yakima mounts, nothing special except overpriced from the dealer. But it will be tight to get 3 bikes on the factory crossbars. Using the Mazda rails with Thule, Yakima Railgrab or Whispbar Thru bars will give you more crossbar width and adjustability. I wanted a cleaner and stronger system than the Mazda rails and here's my system. Whispbar custom tracks with Whispbar Through bars.
    I did use a Yakima Control tower w/ Landing Pad 11 that use the same mounting points as the Thule Podium but the long distance between the bars (43") limited the configurations I could set up.
Similar Threads
  1. WTB Roof Racks
    By funtege5 in forum Completed Transactions
    Last Post: 12-24-2011, 10:37 PM
  2. Roof Racks
    By Mz3Hatch in forum Mazdaspeed3
    Last Post: 08-02-2009, 03:10 PM
  3. Roof Racks
    By New Phase! in forum Mazda3 Lounge
    Last Post: 12-30-2003, 03:57 PM
  4. roof racks
    By eting_pro5 in forum Mazda Protege
    Last Post: 10-13-2003, 08:14 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
