CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 9 of 9
Thread: 2002 Protege 5 will not start....might be relay?
  1. #1
    Registered Member
    2002 Protege 5
    Join Date
    Apr 2012
    Location
    TX
    Posts
    2
    Hi everyone,
    New to the forum. I've had my PR5 for 10 years, and up until now its been perfect.
    It wouldnt start, towed to mechanic and had the starter replaced 3 weeks ago.
    Saturday it was clicking when trying to start, power to radio/lights etc, but no ignition.
    I removed the relay, and put right back in, thinking it just got stuck. Started up, several times without problem.
    Did the same thing again yesterday, this time took a picture. Got it to start after reinstalling relay and 30 minutes of waiting. Started again this morning, no prob.
    So my question is, have any of you had the same issue? I am not sure if it is the relay or the connector. And if it is the connector/box how would I go about repair? Replacing the whole thing? Just the wiring harness beneath? I am a girl, and don't want to go into a shop blind about the issue, and be taken advantage of, even though I know my fair share about car repairs, electrical is not my stong suit.
    Thanks!!
  2. #2
    No words bazooka joe's Avatar
    Donated: $40
    Miata & NEMOC Moderator
    2016 Miata Club, 2004 MSM, 2014 CX5 Touring, Honda 1976 XL 175
    Join Date
    Oct 2002
    Location
    wbee ma to NC 2016 Jinba ittai
    Posts
    21,180
    looks like you've had some heat/arcing there on those connections..bad/loose connection....it may need to be replaced..try some dielectric grease from your local auto parts store...not sure this will help to much...don't worry, being a guy would not going to stop the dealership from gouging you!
    http://www.permatex.com/products/aut...-Up_Grease.htm
  3. #3
    McNoobin' Jedidiah55's Avatar
    2003 Protege 5 V6 GT
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    also if you are still having problems it might be a bad ground
    but you probably need a new relay
    welcome to the forums
    what part of Texas are you from? I'm an hour east of Dallas but my hometown is in central Texas?
    2003 P5 46k miles KLDE motor with JDM tranny swap w/ lsd - Dead
    2012 Focus - Sold
    2016 Mazda3 HB
  4. #4
    Registered Member
    2002 Protege 5
    Join Date
    Apr 2012
    Location
    TX
    Posts
    2
    I'm in FTW.
    Any ideas on how much that kind of thing costs to repair? The relay is about 80 bucks, but if its the connection...or the ground. Any ideas? I have researched this extensively online but havent found much.
  5. #5
    Registered Member
    Join Date
    Apr 2012
    Location
    Miami
    Posts
    1
    sounds like a sticking relay,....try autozone, they carry the relay for $45.
  6. #6
    Nemo0o skilletrx's Avatar
    Join Date
    Jun 2003
    Location
    Wo0dbr1dge, VA
    Posts
    792
    any idea on the part number for a 03 mazdaspeed protege?
    #1612 SpicyOrange
  7. #7
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    If you're dealing with the same relay as posted in the picture, (fuel pump relay) then it looks like Rockauto has them.
    The numbers appear the same too.
    The Diagram Dude
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    Check the pictures of the relays, they're not all the same, the pin configurations are different.
    The fuel pump relay (at least on my P5) looks like this.
  9. #9
    Join Date
    Jun 2003
    Location
    Wo0dbr1dge, VA
    Posts
    792
    Just FYI to close the loop, it was a faulty connection to my clutch safety switch after the clutch was replaced - in case someone runs into the same issue.
Similar Threads
  1. 2002 Protege 5 start-up issue.
    By Chi3f in forum Mazda Protege
    Last Post: 12-12-2012, 09:39 AM
  2. 2002 Protege 5 won't start
    By P-Nutz37 in forum Protege5
    Last Post: 07-18-2011, 02:08 PM
  3. Replies: 2
    Last Post: 12-06-2010, 09:26 AM
  4. Relay kit for protege
    By rapter in forum Mazda Protege
    Last Post: 09-21-2008, 07:24 PM
  5. WTB 2001-2002 fog light switch and relay
    By huskers555 in forum Completed Transactions
    Last Post: 06-27-2008, 12:38 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
