- 2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6
Okay, since upping the boost to 10psi (spiking at times to 14psi) I've been hitting fuel cut. I even dialed it down to 8.5psi but will still sometimes hit fuel cut. Weather has been anywhere from 20-40 degrees in the past couple of weeks, but yesterday it was almost 59. Even at 8.5psi I hit fuel cut. I have NO DTC's current or stored in the fault memory. My boost gauge is showing 20hg of vacuum. I have smoke tested my charge piping to make sure I have no leaks. If I do WOT I am guaranteed to hit fuel-cut at about 4,800-5,000 RPM. I am currently running the SSAFC V1 with the "Superstock" map. My other mods are listed below. If anyone has any incite to help me correct this issue, I'd be greatly appreciative.
