Thanks for the info Davicho.
The saga continues…sorry for hijacking your thread damaludin. I’ll create a new thread if the mods ask me to.
I picked up the 5 yesterday and my mechanic told me 2 new sounds are coming from the front.
-Creaking, crunching when slowly driving over speed bumps, potholes or uneven surfaces
-Humming (especially noticeable when driving on the highway)
He thinks the creaking\crunching is a result of bad control arms or the struts or springs not being installed properly (installed by a different mechanic)
As for the humming, he thinks the front right wheel bearing is bad (potentially a result from him torching the seized wheel hub in the axle/steering knuckle when working on installing the new control arm)
So I’ll have the car for a week and then back to the shop…argh!
In regards to the rear, he kept the Moog end links and installed new “redesigned” Mazda stabilizer bar bushings and brackets as per recommendation from a friend of his who works at Mazda. I’ll probably order the poly bushings and the 2012 Mazda brackets Davicho used later but the Mazda ones will do for now.
