Tech, I bought the 2012 bushings and U-braces for the rear sway bar only. Again, I had to bore out the center of the bushing a little bit with a dremell so that I can install them on my 2006 sway bar. If you get the 2012 sway bar also then it should be just as easy as bolting up. BTW the bigger 2012 U-braces for the rear sway bar bushings bolt right up to the subframe (meaning the distance between the bolt holes line right up to the threaded hole in the subframe).
Paranoia and knowing the TSB related repairs were not done got the best of me so I had my mechanic replace a whole bunch of parts last week:
- rear Shocks (KYB Excel G)
- rear Shock Coil Springs (Mazda)
- rear Coil Spring seat rubber (Mazda)
- rear Upper Control Arms (Beck/Arnley)
- rear Lateral Links (Beck/Arnley)
- rear Trailing Arm Bushings (Moog)
- rear End Links (Beck/Arnley)
- rear Sway Bar Bushings (Energy Suspension-red polyurethane)
My mechanic thought I was over-doing it but in the end, he did find the old shocks, springs, end links and bushings were pretty bad.
I'm not done yet! I'll be getting the following front suspension parts replaced in the next couple of weeks:
- front Control Arms (Beck/Arnley)
- front End Links (Beck/Arnley)
- front Sway Bar Bushings (Energy Suspension-red polyurethane)
- Front Struts (Monroe Sensi-trac) *if my mechanic finds the existing Monroe's to be leaking like the dealer claimed (which were installed by another mechanic back in January this year)
Before deciding on changing out all of these parts, I was thinking of getting various poly bushings but I couldn't find any for the 5, other than the stabilizer bar bushings. Does anyone know if
these Mazdaspeed 3 bushings would fit the 5?
