There certainly are two screws up at the front. The lower requires removal of the wood/black trim that "arcs" through the console, and continues at the bottom.
However, even after removing these, my trim isn't budging. They certainly need to slide forward, since you can see the rear of the trim from the back of the console if you open it up.
So far, I've broken some sort of tab which inserts around the front area of the console cubby, and it seems like it is still holding on for dear life further back towards the seat bolster area.
My plan is to remove all 6 pieces and recover them with brushed aluminum vinyl. I've already taken off the door trims, but really want to take them off the console to do a good job. I could just reef on it until something comes loose, but that seems like a bad idea...
For the record, I have a 2007 which is no longer in warranty. Picked it up last week and I'm just fixing it up before it becomes my daily driver...
I can't seem to find this in the service manual I found on this forum. Anyone care to provide me a link which shows anything about removing these console trim pieces?
