Results 1 to 8 of 8
Thread: Moisture in Rear Taillight
  1. #1
    Registered Member
    2011 CX-9 GT AWD
    Join Date
    Apr 2010
    Location
    Wisconsin
    Posts
    38
    2011 CX-9 - Getting Moisture in rear Tail Light in heavy rain and after car wash.
    I there a TSB for this ?
  2. #2
    Registered Member
    2011 Mazda CX-9 Grand Touring
    Join Date
    Aug 2011
    Location
    Boston, MA USA
    Posts
    93
    Yes there is. It's SB-09-057-10. I have the number because I had the issue just recently after a very heavy rain/wind storm. It bother me that all 4 rear clusters had condensation. From my research here on the forum, it looks like it is a common issue and Mazda won't replace them. They will reseal the gaskets. Please correct me if I am wrong. I am going to my dealer this Friday and will report back then.
    2011 Mazda CX-9 AWD Crystal White Pearl Mica NAV/Moonroof | All Season Mats | Wheel Locks | Roof Rack | Remote Starter | Power Lift Gate | Stainless Steel Bumper Guard | Cargo Tray&Net | ULEVII Emissions
    2012 Acura TSX Wagon with Tech Package Graphite Luster Metallic | All Season Protection Package | Bodyside Moldings | Splash Guard
  3. #3
    Biggie T Skinny helbigtw's Avatar
    CX-3, CX-5 & CX-9 Moderator
    08 CX-9 GT Fwd, Bose/Nav, BSM,Compass/Homelink, Pwr Lift,Tow
    Join Date
    Feb 2011
    Location
    Lexington, KY
    Posts
    2,088
    If you want the full version of this TSB, just PM me. Basically the TSB says "this is normal, and we're not going to do anything about it." Literally, Mazda says that #1, it is completely normal and #2, they won't do anything about it because it IS normal.
    (I don't agree that it is normal, because over time, repeated condensation causes yellowing and discoloration & staining inside the lens) but nonetheless, Mazda aint gonna do a thing about it.
    08' CX-9 GT FWD
    Gray Mica with Black Interior
    Nav/Bose/Sunroof/Bluetooth /Rack&Crossbars/BSM/Pwr Lift/Homelink Mirror/Tow Pkg/All Weather Rear Mats
    K&N drop-in filter/Centric E-Coated rotors & Centric Posi-Quiet Ceramics /2 Yakima ForkLift Bike Trays/ Weathertech front mats
    Tires: Nitto NT421Q
    Oil: Mobile One Full Synth & Mobile One Extended Performance filter
    Problems to date: Blower motor relays replaced once, intake manifold rear brace was missing from factory build, headlamp motors weak, windshield wiper plastic cap, rear strut leak.
    Mileage: 100k
    Job: Material Damage Adjuster
  4. #4
    Registered Member
    Join Date
    Aug 2011
    Location
    Boston, MA USA
    Posts
    93
    Quote Originally Posted by helbigtw View Post
    I absolutely agree with you. Moisture will hold dirt which can stain as well. I had similar issues with my 2004 Acura TL which had poorly sealed headlight housing as well and now there is clouding where where was once moisture. It is less likely to be noticed in the taillights since it projects rearwards vs. headlights where the amount of light projected can be diminished.
  5. #5
    Registered Member Lindyrect's Avatar
    2007 GT FWD, Bose/NAV
    Join Date
    Dec 2007
    Location
    Chula Vista, CA
    Posts
    600
    I don't have the moisture issues, but I do have white artifacts showing up in the tail lenses. I believe they are where the lenses did not laminate well and the layers have been rubbing on each other.
  6. #6
    Registered Member
    CX 5 Grand Touring 2017
    Join Date
    Oct 2017
    Location
    Delaware, USA
    Posts
    16
    Moisture is appearing in my '17 CX-5 turn signal lenses after I wash car at home. but it eventually dries up.
  7. #7
    Join Date
    Feb 2011
    Location
    Lexington, KY
    Posts
    2,088
    Well mine is 10 years old with 101k and my tail lamps get slight moisture after a warm hand wash, but nothing has happened, no yellowing or discoloration of the lenses, so its all good.
  8. #8
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    847
    Usually if you get any minor condensation, it can be mitigated by removing the housing from the car, applying a bead of silicone caulk (use the outdoor/weatherproof kind) to the seam where the lens meets the housing, then taping a few silicon packets to the back of the housing. Those silicon packets are usually found in product packaging. They help to absorb moisture.
    If the housings only fog up after a car wash or rainfall, just taping some packets on the housing may be good enough.
Similar Threads
  1. Will warranty fix cracked rear taillight?
    By iracer7 in forum Mazdaspeed3
    Last Post: 01-12-2010, 10:27 PM
  2. Protege 5 Rear Taillight's
    By JDMJNKY in forum Completed Transactions
    Last Post: 01-03-2010, 12:57 PM
  3. Rear taillight leak
    By gbureasds in forum Mazda6 Accessories & Appearance
    Last Post: 02-14-2007, 06:57 AM
  4. WTB Drivers side taillight & rear bumper msp
    By Brannon in forum Completed Transactions
    Last Post: 03-06-2006, 08:31 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
