I'm posting this here simply because i don't know what car i will put this engine into, so i'd say this is a Build thread on the FWD conversion only, once i figure out a car to drop it into, i'll start a separate thread
Ok so i know rotary's never came FWD, but i think it would be cool to have a FWD rotary setup, so here is my little side project
So i'm sure some of you have seen the KL powered Miata, they use an adapter plate and an RX7 tranny mated to the KL, so that tells me the flywheel/starter situation works with that setup, so why not use a KL tranny on a 13B?
A friend of a friend is a tool and die maker and he has his own CNC plasma cutter and is very good with CAD drawings, if i am not able to locate a CAD drawing for both the 13B and KL bellhousings, i will get him to make up the CAD drawings using any of my spare components and then cut out an adapter plate for me, if the adapter plate is too big for his CNC plasma, then there is a local laser cutting shop that i can have the plate made at
I figure the starter placement on the KL trans should work nicely on a 13B, and since i have a couple spare KL tranny's, the first step is to get a 13B to mess with
I know the biggest hurdle i will run into is the exhaust manifold interfering where the axle will go, my plan is to make a custom manifold for it to clear, worst case senario, i can "clock" the engine a bit the help with the clearance
$200 later and here i have a complete setup from an 89' RX7, wiring harness/ECU etc. (tranny will be F/S later on after the adapter plate is made)
And i started taking a few things off the motor to get an idea how its built
The clutch looks pretty similar to the KL clutch and the spline count matches the KL clutch which is awesome cause i won't need to mix-match components to line things up
Now I do understand there will be a bunch of custom work for this setup to work, but that just adds to the cool factor if i manage to pull it off, this will most likely be a very slow build as well since its not my priority build, i still have a festiva to finish turbo'ing and a 323 that needs a new engine, but i will update this thread as i make progress here and there
Anyways, wish me luck lol
