I have the two-piece Weathertech liner. If you wish to use the rear seat, just disconnect the smaller portion of the liner that corresponds to the back of the third row seats. The truck was traded, but I still have it. The redesigned Weathertech is now all one piece.
I also have a 20" OEM hypersilver wheel mounted on a Spec-X tire with 50-60% tread remaining, as well as a set of two Spec-X's with 40-45% tread remaining, and a set of two OEM Bridgestones with 85-90% tread remaining.
I also have the entire crossbar set-up for factory roof rails, and a set of rear OEM brake pads.
When my '08 was rear-ended and repaired to the tune of $16K, I unloaded it to cut my losses (but sued the at-fault carrier for $2K to cover the diminished value).
Finally, I have a set of the all-weather mats Mazda puts out. They're black, all in great shape except the driver mat which has some material wear.
I'm in the Baltimore area, if you're local and interested PM me. Unless you're looking for something for free, I'm sure you'll find me more than fair.
