A leak in the EVAP system. Usually, it's just a loose gas cap. Remove and reinstall the cap, be sure you get your three clicks. Clear the code and see if it comes back.
If that doesn't keep the code from reappearing, check under the hood. You have the purge soleniod valve and the catch can. Check the hose there. The purge solenoid valve has a hose going to the intake manifold just behind the throttle body and another going to the catch can. The majority of the EVAP system is back by the fuel tank, a canister, a couple of valves, an air filter, and hose connecting it all.
