VersaTuner - tuning software for Mazdas
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: 2jz gte fc rx7
  1. #1
    Registered Member turbotim's Avatar
    1987 mazda rx7
    Join Date
    Nov 2011
    Location
    central alberta canada
    Posts
    19
    Cool 2jz gte fc rx7
    I am new here, found this forum looking at engine swapped rx7's.
    here is my car, I finished the swap last winter and had a fun summer driving it.
    hope you like it.[IMG][/IMG][IMG][/IMG]
  2. #2
    1987 mazda rx7
    Join Date
    Nov 2011
    Location
    Posts
    19
    turbo 2jzgte
    usdm turbos
    3inch turbo back exhaust
    fmic
    cold air intake.
    arp head studs
    r154 tranny
    fidanza aluminum fly wheel
    snow performance water meth injection
    fuel cut controler
    255lb fuel pump
    boost controler
    boost set at 19 psi, but falls off to 16 after 5k rpm, waste gate springs not holding.
    ford 8.8 irs diff, stock mazda diff broke at the start line with a 3500 rpm launch.
    stock 2jz ecu.
    stock fuel injectors.
    car ran 12.8@117mph.
    could have ran a better e/t if the tranny wasn't so notchy, wish I spent the money on that 6spd, now.http://www.youtube.com/watch?v=ARl8XRp0FtA
  3. #3
    R.I.P. #53 MSP Cruzanspeed's Avatar
    Mazdaspeed Protege
    Join Date
    Oct 2005
    Location
    Orlando, FL
    Posts
    591
    Nice car bro.
    GT28RS turbo, MAM turbo manifold, perrin front mount intercooler, GHL turbo back exhaust, SLS Pass. mount, medival front & rear motor mounts & trans. mount, fuel cut defender, perrin fuel rail, walbro 255, vibrant vacuum block, dual blow-off valves greddy & stock(no more turkey), gemini cf hood, dg cf mirror covers & eye lids, custom tinted taillights, konig holes 18" wheels, tien s springs, autometer egt, boost, oil psi, guages, aem wideband, ForceFed Column Pod & a few other mods.
  4. #4
    1987 mazda rx7
    Join Date
    Nov 2011
    Location
    Posts
    19
    thanks.
  5. #5
    Registered Member StealthWyvern's Avatar
    03.5 YLW MSP
    Join Date
    Mar 2006
    Location
    Jaxs
    Posts
    9,954
    Looks good. Do you plan on installing power steering, ac ect?
  6. #6
    F10 what? sephiroth's Avatar
    2018 Tesla Model 3 AWD LR
    Join Date
    Aug 2006
    Location
    Suffolk, VA
    Posts
    1,293
    The tuck-away quart of oil made me laugh. You got rid of that problem I thought!
  7. #7
    1987 mazda rx7
    Join Date
    Nov 2011
    Location
    Posts
    19
    lol ya the oil was there because when I put the engine in it burned oil, due to turbo seals being gone. so I swapped out the jdm turbos for usdm turbos, no more oil burn problem. I forgot to remove it but its not hurting any thing, lol.
  8. #8
    1987 mazda rx7
    Join Date
    Nov 2011
    Location
    Posts
    19
    Quote Originally Posted by StealthWyvern View Post
    yes it has power steering but no a/c, I suppose it could have a/c but I like 260 air conditioning, lol.
  9. #9
    Registered Member dexspeed's Avatar
    2011 Mazda 2/1985 Mazda rx7 GSL
    Join Date
    Oct 2011
    Location
    Ottawa/Trenton, Ontario, Canada
    Posts
    15
    Interesting build. What kind of numbers are you putting down on the dyno? Was that a turbo II dif that you broke initially?
  10. #10
    1987 mazda rx7
    Join Date
    Nov 2011
    Location
    Posts
    19
    Quote Originally Posted by dexspeed View Post
    never put it on the dyno, but the mph calculator says between 380 and 420 whp depending on which calculator you use, based on car weight and trap speed.
    no it was a n/a diff I broke, couldnt take a 3500 rpm launch on a sticky track. the car was a gxl, I just made the decals up cause I thought it would be cool to ad a subtle touch to the car.
  11. #11
    Registered Member
    86 fc3s with 2jz and 88 fc3s with 5.0
    Join Date
    Jan 2012
    Location
    washington
    Posts
    3
    sorry to bring this up but i was wondering if you got any pics on how your powersteering hooked up i have the same motor in my fc but im not sure how to hook up the p/s
  12. #12
    1987 mazda rx7
    Join Date
    Nov 2011
    Location
    Posts
    19
    Quote Originally Posted by towyld2taim View Post
    I had the same problem, no one would answer me on the forums, lol.
    I think what I did was block the small pressure line down at the rack, the large pressure line threaded right into the jz power steering pump, I ran the return line up to a small custom mounted reservoir and from the res back to the return side of the pump.
    the res I used was off a 1g dsm, it was perfect, small enough to fit nicely with out taking up to much room.
    I read that you can plum the small pressure line to the return line and this will give you slightly stiffer steering for better feed back when driving.
    the way I have my power steering hooked up, the steering feels like an old oldsmobiles power steering, it requires no effort at all to turn it, which kinda sux for cornering, but I am a straight line guy any ways so it dosnt bother me that much.
  13. #13
    Registered Member
    Join Date
    Jan 2012
    Location
    washington
    Posts
    3
    i have the pump and res in but people on the forums kept telling me diffrent things like plug the small hole and use the rack that way and other people say put a odd (T) in and run it like that i just can never get a real answer i plan on useing the car for drifting so i would like to be able to handle the counter steer and im not that big of a guy thanks for giving me a real answer because i keep being spun in circles
  14. #14
    Registered Member
    Join Date
    Jan 2012
    Location
    washington
    Posts
    3
    this is how my p/s is hooked up top line is return middle line is high pressure 3rd is pluged is that right only reason i ask is because it seems like its not doing anything but im not sue if maybe the pump is shot does that look kinda like how yours is plumbed
    Attached Images Attached Images
  15. #15
    minitrucker mymmeryloss's Avatar
    13bT Mazda B2600i
    Join Date
    Jan 2010
    Location
    Colorado
    Posts
    1,145
    Gorgeous car man!
    Nice job!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
