M MSP1714 Member : 94 Sentra se-r Turbocharged Oct 14, 2011 #1 with out modding the studs for the rims? info needed.
H HKPRO5 Member : Supercharged Protege5 Oct 14, 2011 #4 5mm should be fine, I run that on my FD wheels. (DD)
N njaremka Wiggity-Wack-O-Tack Contributor : 2012 Mini R55 Oct 14, 2011 #5 5mm would be the max on stock studs and still get decent nut-thread engagement. anything thicker and you will want to seriously consider longer studs.
M MSP1714 Member : 94 Sentra se-r Turbocharged Oct 15, 2011 #6 thanks men. is 5 mm a good change give it a little better look?
