VersaTuner - tuning software for Mazdas
Page 4 of 17 FirstFirst ... 2345614 ... LastLast
Results 46 to 60 of 252
Thread: Fastest klze swap?
  1. #46
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    86
    Well the extra coolant temp sensor on the filler neck is actually a giveaway that it is from a 93. It was the only year that had the extra coolant sensor. Also, the oil pressure sending unit would have been the larger one (a little bigger than a film canister) that was only on 93-94 year Probes if it did indeed come from a Ford. The part number on the ECU would tell me a lot too. That vac line in the back of your manifold was originally hooked up the the HVAC controls on the probe and is true manifold vacuum. Holler at me via PM or start a new thread and we can get your odd running issue resolved.
    Vids will come this weekend when we crank her up.
    Ranting time:
    Im not sure I understand the reasoning behind some people not wanting to share information here. Isnt part of being on a forum like this to share information and to help others instead of rubbing a problem someones having in their face?
    I picked up on the KL MAF conversion after it was abandoned for years and then proceeded to pioneer using it with a turbo setup that allows the use of junkyard parts to boost safely without having to use an FMU or any other engine management stuff. I shared every step I took and answered every question I was asked. Shouldnt that go for pretty much anything?
  2. #47
    McNoobin' Jedidiah55's Avatar
    2003 Protege 5 V6 GT
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    i'm with you, some people mod their cars (or get a mechanic to do it)then come on forums just to brag and im going to have to hit you up on that MAF/turbo set up at some later date
    and do you still need a p5 pinout?
    2003 P5 46k miles KLDE motor with JDM tranny swap w/ lsd - Dead
    2012 Focus - Sold
    2016 Mazda3 HB
  3. #48
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    86
    If you have a pinout that shows every single pin that would be great when we start eliminating the P5 harness/ECU. I kinda have one right now but its a pretty scattered diagram that doesnt show each and every pin, but it should be enough to get the car started.
  4. #49
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    goodluck with the start, its the exciting part
  5. #50
    MP5-ZE Slotege5_2003's Avatar
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Its getting closer and closer.
    Jim, is exactly right here. I almost left this forum because of the hush-hush mentality. We are only here for two reasons.....to get help, and help. If we make friends with people then thats fine, but there is no reason to assume you are better for any reason. Of course Im mainly talking about one individual here. Why he wants to be the only one with AC in a swapped Protege is beyond me. Well the cat is out of the bag here. As soon as this is complete there will be step by step instructions on how to do this. No secrets, just a simple guide on how to make your car kick ass.
    As for the other (jerkit) , Let us know if we can help.
  6. #51
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    how's everything going?
  7. #52
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Still the same. We will start working on it again tomorrow morning.
  8. #53
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    did yall get pinouts?
  9. #54
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    No not yet. I think Jim has it pretty much figured out for now though. We will just need the pinouts for when we are eliminating the harness and ecu. For now we are going to run both.
  10. #55
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    86
    Yeah, tomorrow will be the wiring portion which shouldnt take too much time to complete being that theres not much to splice into to run both harnesses. Jedidiah, I still cant get into that place you sent me the link for. Dunno whats up with that, but like Andy said, I have enough info to get the car running, just not enough to ditch the stock P5 ecu yet.
  11. #56
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Once it gets running its maiden voyage will be to the CAR WASH!
  12. #57
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    lol clean car ftw
    and ill print out some pinouts and scan them for you and ill send jpegs if i can of them
  13. #58
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Awesome, man. I really appreciate you helping us out with this. There aren't many here that are willing to, apparently.
    I'm hoping that I'm just getting a bad first impression with this forum, but time will tell I suppose.
  14. #59
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    idk, i think kl swaps scare ppl
    PINOUTS!!!!!!
  15. #60
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Printing this out as we speak. Thanks, man!
Similar Threads
  1. KLZE swap?
    By enzo ferrari in forum Mazda Protege
    Last Post: 03-15-2013, 01:38 PM
  2. klze swap
    By subsonicman in forum Protege5
    Last Post: 11-14-2009, 06:26 AM
  3. KLZE swap
    By s0n1cm0nk3y in forum Mazda Protege
    Last Post: 09-20-2008, 02:06 PM
  4. klze swap
    By cantstopklze in forum Protege5
    Last Post: 03-07-2008, 04:21 PM
  5. Looking to swap for klze or de
    By horaaan16 in forum Other Mazdas
    Last Post: 10-06-2007, 04:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
