Made in USA and Free Shipping on all orders shipped inside the US.
Page 2 of 17 FirstFirst 123412 ... LastLast
Results 16 to 30 of 252
Thread: Fastest klze swap?
  1. #16
    MP5-ZE Slotege5_2003's Avatar
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    I have the one for the probe. I really appreciate your help, though. You have by far been the most help. Keep any and all ideas you have coming. Thanks a million.
  2. #17
    McNoobin' Jedidiah55's Avatar
    2003 Protege 5 V6 GT
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    also i wired a fan on cause it would never kick on when i wired it and for your temp gauge to pull a p5 sensor and connector out and throw it in the kl and run the wires back to the p5 ecu
    its been awhile since i messed with the wiring, so im trying to remember everything and trying to find my p5 diagrams
    2003 P5 46k miles KLDE motor with JDM tranny swap w/ lsd - Dead
    2012 Focus - Sold
    2016 Mazda3 HB
  3. #18
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Ill keep the fans in mind.
  4. #19
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    The baby
  5. #20
    OG mazda owner~ xxxmonoxidechil's Avatar
    Potential Scammer!
    Join Date
    Oct 2006
    Location
    rockford, IL
    Posts
    1,498
    if you can find a odb1 mx3 ecu, try that, with the je-50 vaf. that was the best combo we found for the KLZE in the protege. i really hated that i couldnt run that combo in my odb2 mtx kl 626. but i just got done doing a full maf conversion. so now im even happier im odb2.
    and that motor looks hot man! love the valve cover.
  6. #21
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    86
    Heh, Im glad the MAF conversion is spreading here too.
    This is Jim and ill be taking the lead on this swap. I have no concerns at all on the mechanical portion of the swap at all, especially since we have a probe donor car that will be literally 3 feet from the 5. The main goal of this isn't necessarily performance (okay, maybe it is a little :P) but we want it to be just like as if it came with the KL from the factory, which includes keeping all the amenities and creature comforts. I want to basically completely remove the FS engine harness and ECU completely and replace it with the Probe equipment, so I would like to have as much of the factory wiring diagrams as I can to make this possible. I have several volumes of the Probe EVTMs so Im covered on that end. Im not fond of the idea of having to hack the existing harnesses or have to run two ECUs. Even if this doesnt turn out to be the fastest swap, I want it to be the most complete and clean swap. Lots of pictures will be taken and I will be keeping notes for a detailed writeup on how to make this work as if it came this way from Mazda.
  7. #22
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Quote Originally Posted by xxxmonoxidechil View Post
    Thanks man. I appreciate it.
  8. #23
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Quote Originally Posted by forced_pgt View Post
    Welcome, Jim. Its about time you posted on here. Yes clean, and function trumps performance, and speed on this build. Of course, a little of all of them wouldn't hurt.
    We also decided to go with the probe tranny. Just a side note.
  9. #24
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    Quote Originally Posted by Slotege5_2003 View Post
    The baby
    i see you already started cutting your wrist, thats good it better to now then later
    i dont think you will need the je50 since you have the probe ecu it will give you different reading if its meant for the kl02? vaf and will dump loads of gas and you will have a rough idle unless the chip is made for the je50 and the maf conversion might be your best option, idk much about the probinator ecu
    as for running only the probe ecu only i think you will have problems, cause the p5 ecu has about 80-100 wires where as the kl has about 60-70 wires and the idk if the probe ecu can work the p5 headlight and all that good electrical crap of volts, and ohms matching up
    you might have to make a throttle cable mount for the p5 throttle cable idk if you can use probe cable, someone said you can flip the piece on the throttle body and it works but idk
  10. #25
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    The wiring is going to be for Jim to figure out. I get really uncomfortable with stuff like that. We will be doing most stuff on the fly so it will be quite interesting.
    Havent thought much about the throttle cable either. Im glad you said something about it though. Ill be checking into that soon.
  11. #26
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Just a couple more days..............
  12. #27
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    is your dist in good shape?
  13. #28
    2003 Mazda Protege5
    Join Date
    Jul 2011
    Location
    Knoxville, Tn
    Posts
    170
    Yeah
  14. #29
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    86
    Quote Originally Posted by Jedidiah55 View Post
    Im going to tap the probe ECU into just a few wires to begin with just to get it up and running but then I will slowly be dismantling the wiring and removing the stock ECU. The biggest reason for the extra wires on the P5 ECU is that its OBDII and thus has more extensive emissions equipment monitoring. The difference between an OBDI and OBDII KL probe is probably in the realm of 20+ more wires.
    The 95+ year disty very rarely fails like the 93-94s did due to an upgraded internal ignitor. Im still running my original with 284k miles on it and it doesnt even blow spark under boost with stock plug gap in the middle of winter.
  15. #30
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    86
    Going smoothly so far. Had a very late start today but much progress was made. Started with this at about 12:30 and a little over an hour later we had...
    Went to the local BBQ place and over ate some killer grub which wasnt the greatest idea we've ever had because we were feeling pretty much worthless when we returned. lol. Anyway, I was looking at the stock rear mount and it was utterly demolished and, well, wimpy. After some small modification to the probe mount (which already had a RR poly insert) we had some added beef. Only needed to trim the back of the mount nearest to the firewall down about 1/4 inch.
    Around 4ish we had her new heart in place.
    Power steering is pretty much figured out using the Probe pump and stock P5 pressure line. The return line will need to be custom due to the length of the required tubing. Ill get pics of that once its completed. Going to tackle AC and cooling tomorrow and possibly some wiring. The stock P5 radiator will be used because the Probe rad is about 4 or 5 inches too wide and hits the AC lines, so the hoses will have to be completely custom. The stock AC fan is going to be modded and moved over to the drivers side and a 14" slim line fan will be put on the passenger side to clear the header. You cant see it in the pics but SSAC/ ebay headers are being used, thus the minor fan clearance issue. If we had stock logs it wouldnt be a problem.
    Will update with more tomorrow.
Similar Threads
  1. KLZE swap?
    By enzo ferrari in forum Mazda Protege
    Last Post: 03-15-2013, 01:38 PM
  2. klze swap
    By subsonicman in forum Protege5
    Last Post: 11-14-2009, 06:26 AM
  3. KLZE swap
    By s0n1cm0nk3y in forum Mazda Protege
    Last Post: 09-20-2008, 02:06 PM
  4. klze swap
    By cantstopklze in forum Protege5
    Last Post: 03-07-2008, 04:21 PM
  5. Looking to swap for klze or de
    By horaaan16 in forum Other Mazdas
    Last Post: 10-06-2007, 04:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
