Compare auto reliability with reliable results at TrueDelta.com!
Page 17 of 17 FirstFirst ... 7151617
Results 241 to 251 of 251
Thread: Fastest klze swap?
  1. #241
    McNoobin' Jedidiah55's Avatar
    2003 Protege 5 V6 GT
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    for the a/c delete just leave the de-pin the harness if something think the a/c is running
    and for me the first thing i connected was the a/c relay and i tested it
    i had the p5 a/c relay wire ran to the kl ecu and everything else was hooked to the p5 ecu
    and the kl ecu grounded the a/c relay which cause the a/c compressor to run so the ecu should think the a/c is on but idk how to make the ecu think the a/c is off
    2003 P5 46k miles KLDE motor with JDM tranny swap w/ lsd - Dead
    2012 Focus - Sold
    2016 Mazda3 HB
  2. #242
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    this works some....how
    when the a/c button is pushed and the blower motor is on the condenser fan kicks on so i wired the a/c relay's relay to the condenser fan relay so when the condenser fan kicks on the a/c clutch kicks on
  3. #243
    Registered Member
    2002 Protege5
    Join Date
    Apr 2011
    Location
    Vancouver, BC Canada
    Posts
    450
    looks good to me. These cross platform swaps generally end in odd wiring setups. Just a hint, write it all down for diagnostics later lol.
  4. #244
    Registered Member
    2002 P5 Wag
    Join Date
    Jan 2011
    Location
    League City, Texas
    Posts
    836
    ahem... "And information sharing for the rest of us slobs".
    ha! Glad to hear it worked man!
    KL swapped 2002 P5. <<< check
    50 shot on KL <<< check
    turbo setup on KL <<< check
    Fully forged bottom-end and upping the boost <<< check
    Meth Injection, weight reduction, and fine tuning <<< In progress.
  5. #245
    Join Date
    Nov 2010
    Location
    Texas, off of I-30
    Posts
    405
    one problem
    i dont think the a/c compressor will be able to shut itself off so idk, so be careful
  6. #246
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    85
    Well, picking this up again. Sorry for the absence. A lot has happened in the last year with other projects, including the car being wrecked a second time, me buying the car from Andy, and turning the Probe into a twin turbo project which took up most of the fall and winter. The P5 is now my daily and has been awesome. Anyway, the A/C was never completed and the sweaty season is now in full swing so it would be REALLY nice to get it going. I need to put the system under vacuum and check for leaks before I really do anything.
    Im thinking the easiest way to do this will be to bring the P5 ecu back since it is set up for this system. Feed it power, grounds, RPM signal from the tach converter, and of course the A/C inputs and outputs. I would almost rather use the Probe ECU for all this but the A/C system on the Probe is a lot more complicated as far as multiple relays, extra pressure switches, etc. Sadly I threw away the P5 ECU connector a while back so I have to track another one down before I can start the wiring.
    There will come a time when you believe everything is finished. That will be the beginning
    I drive a Probe. It goes well. http://youtu.be/OOIkpFIGJfU
  7. #247
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    85
    Got an ECU pigtail that I am streamlining for the compressor control. It wont be doing anything other than control the compressor and condenser fan.
    Got a few questions if anyone knows. On a stock FS P5, if the key is in the run position and the engine is off, will pushing the A/C button cause the compressor clutch to engage? Im guessing it will have to see engine RPMs to engage but it would be a lot easier if it didnt. lol. Assuming is needs to see RPMs, I will have to try using the KL's 6 tooth crank pully and single tooth cam sensor. Is the stock FS cam sensor a hall sensor?
  8. #248
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    85
    So doing some more exploring I found that the A/C system in the Protege is far simpler than I first thought. I will not be using the stock ECU like I was. Instead I will just wire in the A/C switch to a relay, which will cause the fans and compressor clutch to come on all at once. I checked the low pressure switch on the drivers side and it is closed so it presumably opens under normal conditions and closes when pressure drops too much. There is a high pressure switch built into the FS compressor, which cuts power to the clutch directly and is normally closed during normal operation. Using these two switches I can wire in a relay that will cut power to the fans/compressor if either switch is tripped. This will be far easier than dealing with trying to make the FS ecu work.
    The FS compressor will need a little work though. It needs to have the KL clutch and pulley swapped onto it since the FS runs one less rib in the A/C belt. It is pretty straight forward. Take the bolt out of the center of the pulley and remove the "pressure plate" from the center. Remove the snap ring and slide the pulley off. Remove the electromagnet via the 3 phillips screws. Re assemble the same way on the FS compressor. There may or may not be shims installed between the clutch "pressure plate" and the drive axle. Get the clearance small enough that the clutch doesnt drag but no so far that the rubber in the pressure plate isnt over stressed when the clutch is engaged.
    The FS compressor will not bolt up directly to the KL A/C bracket. The upper left bolt is the only one that will line up the compressor properly to the belt. so an alternate bracket will need to be fabbed, which is not hard to do. I ordered a 6"x6"x3/8" aluminum plate off ebay for 15 bucks and should be here before next weekend.
    Completed FS compressor with KL clutch/pulley.
    This is the model A/C clutch im using.
    Should make some more progress next weekend. Want to have it going by the end of the month.
  9. #249
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    85
    The 4 cylinder compressor is now mounted up to the aluminum plate that I fabbed up. Spaced it away from the block for clearance and through bolted the compressor to the plate.
    Im going to get the system checked for leaks/ filled on monday morning. Once the system is full, I will setting up this simple circuit I threw together last night to bypass the entire stock system, as I believe it will be the easiest way to run it while still having the safeties.
  10. #250
    Registered Member
    Probe GT KLZE turbo
    Join Date
    Aug 2011
    Location
    knoxville
    Posts
    85
    Life has been hella crazy. I didnt get a chance to do much to the car last year due to other projects etc. I finally turned my attention to the A/C again and after replacing a leaking line and getting a hybrid pressure safety switch, I have ice cold A/C. Its rigged on a toggle temporarily running through both high and low pressure safety switches as well as activating the fan for the time being. I will soon be wiring it up to be controlled my the stock KL computer as well as utilizing the stock P5 A/C amplifier for proper compressor cycling. Hopefully it wont be another year till the next update. lol.
  11. #251
    Registered Member
    Mazda, 02 P5
    Join Date
    Aug 2015
    Location
    London ky
    Posts
    4
    all very helpful with my swap I'm brainstarved so this all good lol
Similar Threads
  1. KLZE swap?
    By enzo ferrari in forum Mazda Protege
    Last Post: 03-15-2013, 01:38 PM
  2. klze swap
    By subsonicman in forum Protege5
    Last Post: 11-14-2009, 05:26 AM
  3. KLZE swap
    By s0n1cm0nk3y in forum Mazda Protege
    Last Post: 09-20-2008, 02:06 PM
  4. klze swap
    By cantstopklze in forum Protege5
    Last Post: 03-07-2008, 03:21 PM
  5. Looking to swap for klze or de
    By horaaan16 in forum Other Mazdas
    Last Post: 10-06-2007, 04:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
