E EDM6-zoom zoom Member : 06 mazda 6 Oct 10, 2011 #1 What should the tire pressure be on a 2011 Mazda 3?
H HKPRO5 Member : Supercharged Protege5 Oct 10, 2011 #2 I run about 35psi in mine, if you check in the driver side door jam it shows you the proper pressures.
N newb Member : Mazda 3 5-door 2010 Oct 15, 2011 #3 HK's got the right location - just check there. My 2010 is 32 PSI cold with the stock 17" wheels.
