Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: P2177 - System too lean off idle
  1. #1
    Registered Member Grommish's Avatar
    06 BCM Speed6 GT
    Join Date
    Apr 2005
    Location
    Cincinnati, Ohio
    Posts
    66
    Ok, so out of nowhere the CEL pops on, and tosses me a P2177. I know its a lean code, however, there isn't much on here about it.
    I do have a SRI, but I've been running it for almost 9 months now without issue. This is THE first time the code has popped.
    I'm pulling 20Vac on the guage, so I don't think its a vac-leak. Any other suggestions? I'd rather not throw the stock air-box back on, but of course will if that is what it takes. The SRI is a no-name that I got from a friend of mine who was running it on his CX7 for years without an issue either.
    No bogging, no hesistation, no physical symptoms.
    Suggestions?
    2006 Black Cherry Mica MazdaSpeed 6 - ZooM ZooM Bishes!
    2003 SVT ZX5 Focus - The Grocery-Getter Go-Kart
    1998 The POS DEFECTIVE ZX2 - Now with moar ENGINE FIRE!
  2. #2
    Christmas Tree Kiseliok's Avatar
    maz-duh
    Join Date
    Mar 2008
    Location
    Cleveland, OH
    Posts
    1,068
    I was getting that code, and the on-idle one, when I had a very small vacuum leak. You my want to invest into vacuum testing everything before the turbo. IIRC, if there was a leak somewhere between the IC and IM, then you'd be running rich, as you'd be losing air, so this leak has to be somewhere between your MAF and the turbo... not much distance, I know, but definitely worth checking/reclamping.
    Are you using any kind of tuning solution?
    Fez: Christmas Tree a.k.a. Smoke Screen
  3. #3
    06 BCM Speed6 GT
    Join Date
    Apr 2005
    Location
    Cincinnati, Ohio
    Posts
    66
    Yah.. I can certainly check that easy enough. Like I posted, the vac guage is showing 20vac at idle (like it always has), but *shrug*. I don't have idle issues or hesistation or det.. so.. Its odd..
    Nah.. No tuning, the car is basically stock as far as the engine goes. The SRI (again, been on a while) is the only change for it other than the line for the guage.
    Thanks for the reply!
  4. #4
    maz-duh
    Join Date
    Mar 2008
    Location
    Cleveland, OH
    Posts
    1,068
    Then yes, definitely check intake/inlet everything. If that's not the case, we'll have to start brainstorming in this biatch ...
  5. #5
    Registered Member ms6DiGi's Avatar
    Donated: $25
    Mazdaspeed6
    Join Date
    Nov 2008
    Location
    Los Angeles, CA
    Posts
    77
    I just had that code for a while, it was because my LTFTs were 20.3% at one point. Which I believe automatically triggers this code. Car still drove perfectly but since the computer had to compensate >20% it popped up. Do you have a Dashhawk to check?
    Once I fixed the problem it instantly went away.
    2013 Evo X GSR SSS
    SOLD - 2006 Mazdaspeed6 - Cobb AP Stage 1 - Mazdaspeed Coilovers - Cobb SRI - ETS TMIC - Corksport Catback - OBX Test Pipe - TWM Stage 2 w/weighted shifter - ITV 22 - Varrstoen wheels
  6. #6
    06 BCM Speed6 GT
    Join Date
    Apr 2005
    Location
    Cincinnati, Ohio
    Posts
    66
    Quote Originally Posted by ms6DiGi View Post
    No DH. Eventually I'll get an AP, but its a ways off.
    So I checked all the vac lines I could see and did a propane test (unlit torch around the engine bay, waiting for the RPM's to jump) and got nothing. Threw in a bottle of injector cleaner, just in case I've got gunk, so I'll see if that does anything.
    Nothing was loose. I kicked the negative cable to reset the PCM and the LTFT, got about 40 miles and it popped back on. Ugh..
    Digi, what was your issue that caused the Longterm to spike?
  7. #7
    Donated: $25
    Mazdaspeed6
    Join Date
    Nov 2008
    Location
    Los Angeles, CA
    Posts
    77
    Well I had a Mazdaspeed CAI installed in my car, and I was in the process of swapping it out for a Cobb SRI (to be compatible with an OTS AP map) and I noticed a giant rag lodged next to my filter from last time Mazda had their hands on my car... Now I'm not sure if the CAI didn't agree with my car since it was untuned (I've heard a lot of people getting between 14%-20% ltft's with this cai), or if it was the rag, but with the SRI installed my trims dropped down to <10% untuned.
    There is a chance your SRI made your fuel trims jump an extra percent (your buddies car may have been running at 19%) or two to hit 20% where the CEL automatically lights. I'm no pro but I just dealt this with problem last week, so if all the simple tests and fixes don't work, maybe try the Cobb SRI.
  8. #8
    06 BCM Speed6 GT
    Join Date
    Apr 2005
    Location
    Cincinnati, Ohio
    Posts
    66
    Perhapse. I've been running this SRI for 9 months now, through the winter AND 14 days of 90+ degree heat here in Cincinnati. That's what makes this frustrating, as there is nothing I've changed or done. Meh! I'm gonna swap back the stock box and see what that does..
  9. #9
    06 BCM Speed6 GT
    Join Date
    Apr 2005
    Location
    Cincinnati, Ohio
    Posts
    66
    Update:
    Swapped the stock box back on and cleaned the MAF, code hasn't come back yet. I'm wondering if it was a combination of the higher LTFT's associated with the SRI's plus a slightly dirty MAF causing it to spike above the 20% threshhold.
  10. #10
    Donated: $25
    Mazdaspeed6
    Join Date
    Nov 2008
    Location
    Los Angeles, CA
    Posts
    77
    Ahhh that must be it then. Good to hear you found the problem and glad I could help! I guess you can either try a different SRI, or stay stock and get an AP in the future.
  11. #11
    Registered Member ppe4life's Avatar
    mazdaspeed 6
    Join Date
    Aug 2008
    Location
    Chicago
    Posts
    32
    what kind of SRI were you using? i am currently using AEM CAI and i had the same code. i had some assistance with tuning through COBB to compensate, but now the car smells rich due to that and i can even smell it inside the car. i am thinking of going to Corksport SRI.
  12. #12
    06 BCM Speed6 GT
    Join Date
    Apr 2005
    Location
    Cincinnati, Ohio
    Posts
    66
    Honestly, it was a no-brand one that worked fine for a few months before I got the code. I returned to the stock box and cleaned the MAF and it went away.
    That being said, I experienced it again under the stock box while on a trip from Cincinnati to Eastern PA. I was getting on the on-ramp to the Interstate and romped it to get to speed, it bogged, went into limp mode, and threw the same code. I sat on the shoulder for about 10 mins, cleared it with my scanner and continued on my way without the issue returning.
    The only thing that connects the two incidents was the gas. Both times I had put Kroger gas into the tank.. I've not been back since.. The engine doesn't seem to like it, as I've got a buddy who owns a CX-7 have this same issue (with the same gas).
    I've been sticking to BP or Shell ever since, no issues..
  13. #13
    06 BCM Speed6 GT
    Join Date
    Apr 2005
    Location
    Cincinnati, Ohio
    Posts
    66
    Small update:
    After putting the stock airbox in, I'm still get the Lean code. I've determined in caused by my driving style.
    I've got a FAO (Fixed Ankle Orthotic) on my right leg, which means no ankle movement (movement comes from the knee). Since the Speed6 has such a sensitive throttle (DBW?), I'm actually leaning the A/F during normal driving. Letting the wifey drive, or me romping on it, causes the CEL to clear..
    I've got no idea what to do now, but I'm also not sweatin it like I was. Thanks to everyone who offered suggestions!
  14. #14
    06 BCM Speed6 GT
    Join Date
    Apr 2005
    Location
    Cincinnati, Ohio
    Posts
    66
    Necro-Bump update:
    I finally threw a second code. So I was throwing a P2177 and a P2188. These two in combination directed me straight towards the TSB on the bad factory Upstream O2 sensor. If I had cracked, it was a hairline and then decided to give up the ghost. At no time did I ever get a CEL for the Sensor itself.
    Dealer Price: $240
    RockAuto: $105 shipped with my 5% discount.
    Replaced the Upstream with a NTK Wideband OE replacement and by Jesus, it works swimmingly! I was second owner for the car, and this is the first time I've truly experienced "Mazdaspeed".. I spool in first and second now (didn't before) and I don't hit fuel cut during WOT (happened only occasionally). That almost inperceptable hesistation/stutter is also gone. Outstanding results.
  15. #15
    06 BCM Speed6 GT
    Join Date
    Apr 2005
    Location
    Cincinnati, Ohio
    Posts
    66
    So after a day and a half on the new O2 sensor, its back. Fuuuuuh..
    Back to the drawing board.
Similar Threads
  1. Running very lean at idle
    By neysha_eddie in forum Mazdaspeed Protege
    Last Post: 05-08-2010, 01:58 PM
  2. Lean Idle
    By HondaEat-R in forum Mazdaspeed Protege
    Last Post: 10-10-2009, 02:27 AM
  3. too lean at idle cel
    By dealler_81686 in forum Mazdaspeed3
    Last Post: 07-10-2008, 10:54 PM
  4. AFC = lean at idle?
    By Wingman21 in forum Mazdaspeed Protege
    Last Post: 05-24-2007, 06:54 PM
  5. system too lean at idle?
    By mobomelter in forum Mazdaspeed3
    Last Post: 09-26-2006, 06:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
