I have an 03 MSP, SMIC, GT28RS Running ~8 psi MAF before the turbo. It has a cold air drop in the front corner.
What I have noticed, is that when the car is just getting up to opperating temp. (So I begin using boost) The car is Blazing fast. Spinnin tires in first gear etc.
After a bit the car is a dog, will not even break the tires in first gear. It is noticably slower, as my friend even commented.
I was wondering if this was a heat soak issue? (because the car will not notice how effective the intercooler is ? (because the IAT is before the turbo))
Or I thought maybe it was a closed/Open loop issue, But if so, then when I tromp on the pedal and it goes to open loop, I should be running whicked fast again? and it is not.
Sometimes I will accelerate in 2nd gear and get my boost, but no zoom at all. ? In this circumstance it feels like the more psi i push (the more pedal I use) the more the car resisits and retards the timing...
I am wary of the reflash... and don't know if the driver before me used it or not etc.
I am going to look into some thermo probes for the intercooler, and possibly reading my IAT while I am driving.... Any suggestions?
Is there a way to tell if the car is in open/closed loop? can I probe some signal and get a yes/no for that?
Thanks
-Kyle
Thanks
-Kyle
