So to start off I have an after market radiator/inter cooler, that is leaking and causing the car to over heat. From what I can tell the car has had this after market radiator put in, methanol water coolant installed, cold air intake, fuel control, and turbo timers and a blow off valve. The car over heated back in March and has been parked since then but it's got to get fixed now! I need to replace the radiator but I'm wondering why aren't the fans for the radiator working? I replaced the relay for it, nothing else in the fuse department is burnt out. Every time I start the car when i cuts off it's dead again, and I've tried leaving it running in the hopes that the battery with charge but it doesn't when I cut it off its dead. I also have a gauge that measure the Fuel to Air ratio, when I was driving the car after I bought, I'd step on the gas and the gauge would go all the way in the Fuel, from my understanding I need it to be "Stoich" or in the middle, so I need a good fuel mapping for the car. I'm really new to tuning cars and fixing cars I need so suggestions and help, hopefully the pictures below will help. I really love this car and I really want to be able to drive it again, and hopefully with out having to pay an arm and a leg.
