MasonMetcalfe
- 2002 Mazda Protege 5 Dark Blue
so, my issue is that my gas pedal got sticky, It wasen't hard to push in or pull it up with my foot. but it dosen't quite come up that last little bit. when it was really bad it would sit near 2k rpms. but generally when I came to idle it would idle at around 1200 rpms but i could pull up on the gas pedal and it would return to ussual ~750. and stay there after a light tug up on the pedal with my toe.
this only seems to happen once the engine has warmed up.
What i have done, taken off my SRI and used some throttle body cleaner with a gentle toothbrush and cleaned out the gunk, thought it wasen't that bad. with the intake off I could see the butterfly not completely closing. anyways, it hasen't seemed to help really, might just be in my head, if I give a soft push on the gas itll still sit at 1200 and not return until i pull up on the gas.
after this i unhooked my throttle cable at the throttle body and did some more cleaning and noticed the throttle body clicks completely closed perfectly fine when unhooked. also, the throttle cable doesn't seem to be stiff it slid back and forth perfectly cleanly while unhooked.
any ideas? there is another cable hooked up to the gas pedal that goes somewhere else, though I don't know if its related. any ideas?
