CorkSport.com is MAZDA PERFORMANCE!
Page 1 of 9 123 ... LastLast
Results 1 to 15 of 129
Thread: Jess's 91 BRG LS6 Build Thread
  1. #1
    Registered Member XCLR8TN's Avatar
    2013 Fiat 500 Abarth
    Join Date
    May 2011
    Location
    Munroe Falls, OH
    Posts
    1,841
    Wink Jess's 91 BRG LS6 Build Thread
    Well, I guess this is my build thread. Bought my Miata in 06, drove it and modded it a little more each year, slapped a turbo on it towards the end and now I'm sitting in V8 territory.
    I've been through 3 Neons since I bought it and now have a Mazda 2 as a DD. Little car has staying power (nothing was wrong with the Neons when I ditched them FYI!)
    Here's some pics of how it sat before:
    This....... is my V8 List.
    Parts acquired thus far:
    -LS6 engine with 9,000 miles out of an 01 Corvette Z06, no A/C or PS
    -V8 Roadsters subframe mounting kit (includes tubular subframe, engine mounts, tranny crossmember, and frame rail braces)
    -T56 transmission out of a 1999 Trans Am (6 speed), with B&M short shifter and skip-shift eliminator
    -Monster Stage 3 clutch rated to 700 hp/tq (came with tranny)
    -Drive by Wire throttle pedal from a 97-04 Vette
    -Walbro 255
    -Vette Filter/Regulator
    -AN fittings and stainless lines
    -LS1 Pilot Bearing (LS6 won't work)
    -New Clutch Master Cylinder, bleed lines
    -CTS Diff (05, 54k, 3.42 gears and LSD) and diff vent
    -V8R Stage 2 Mounting kit with optional aluminum driveshaft
    -Refreshed Hubs/Wheel bearings courtesy of Planet Miata, with ARP studs
    -Sport brakes with R4S pads
    -Flyin Miata/V8R oil pan ordered 7/1/11
    Parts that I still need for the swap:
    Electrical
    -ECU reflash to delete VATS and 2 of the 4 o2 sensors it is looking for
    -Speedometer/Gauges in general solution
    Exhaust
    -Headers (debating stainless FM vs coated Sandersons)
    -Exhaust system (want 2.5" or 3" to a Y" to a single pipe back)
    Other
    -I decided I didn't want my ABS anymore (I had been running it relay-less anyways for about a year), so I yanked everything... which means I need a new non-ABS Master Cylinder and new brake lines
    -Cage
    Project goals:
    -Shaved, tucked, and stitch welded bay
    -2200-2300lb curb weight (no A/C, PS, Cruise, ABS, heater)
    -15x10 wheels (need to figure out ideal offset to match up with my rolled/pulled fenders that worked well with 13x8 +4)
    Random notes:
    -OEM Miata wiring harness with plugs for all options weighed 17lbs.
  2. #2
    Join Date
    May 2011
    Location
    Munroe Falls, OH
    Posts
    1,841
    Pics...
    Cutting the tranny tunnel to make room
    What a mess
    Oh hai
    Might as well... stitch welds:
    Shaving the bay:
    Before any filler:
    For anyone that is curious, the "batwing" pan doesn't work with the V8R subframe, the 01 was a 2piece design, I took it off just to see... there's some crazy stuff going on in there. There's literally like 4 sections to it. Thought you guys might want to see!
    Going out to work on the bay in a bit
  3. #3
    Registered Member lizardman743's Avatar
    2003 Mazdaspeed Protege
    Join Date
    Feb 2011
    Location
    Elkhart Lake, WI
    Posts
    1,091
    Sub-zilla.
    2003 Mazdaspeed Protege #35
  4. #4
    Damian Dpwhitehead1's Avatar
    Donated: $25
    LX, MSP 1145
    Join Date
    Jan 2005
    Location
    Owings Mills, Maryland
    Posts
    9,274
    badass!
    Be happy!
  5. #5
    Phenda Bear THE Phen's Avatar
    2013 Abarth, 2004 MSM - FM, '74 BMW Bavaria, 97 Civic EX B18C1
    Join Date
    Jan 2007
    Location
    Munroe Falls, OH
    Posts
    15,768
    Jess are you doing the build in the Falls?
    MOCO ~ Mazda Owner's Corral Operations
    "I always say, the best Lamborghini is the Audi R8. "
    My Fiat 500 Abarth
    My Mazdaspeed Miata Build Thread
    My '74 BMW Thread
    In Ohio? Check us out!
    My Travel Blog - The Chronicles of Phen
  6. #6
    Join Date
    May 2011
    Location
    Munroe Falls, OH
    Posts
    1,841
    ^yup! You walked right past it when you came and got the tranny/ppf ... It was covered up and looked like a sailboat LOL
  7. #7
    ZOMG SOOO HERRA FRUSH!!1! mattxhand's Avatar
    2003.5 Mazdaspeed Protege
    Join Date
    Jan 2010
    Location
    Virginia Beach,VA
    Posts
    375
    AWWWW YEAHHHHHHHHHHHH. This is awesome!
    MODS:
    AWR Rear, Front and Side Motor Mounts
    EBC Drilled & Slotted Rotors
    Falken Circuit Sport II
    HKS BOV V2
    Custom FMIC
    Perrin SRI w/ K&N Filter
    AWR Rear Sway Bar Bushings
    Exedy Stage I Clutch
    Sexy Lady In The Passenger Seat ALWAYS
  8. #8
    Registered Member malaki's Avatar
    00' Mazda Protege SE
    Join Date
    Oct 2009
    Location
    Montréal
    Posts
    118
    awsome! I just wanna see more pict!
  9. #9
    Registered Member stkmp5's Avatar
    2003 Protege5
    Join Date
    Feb 2008
    Location
    Honolulu, Hawaii, United States
    Posts
    191
    Sub
  10. #10
    Registered Troll INeedMoarLow's Avatar
    slammed 02 protege5
    Join Date
    Jun 2011
    Location
    meadville, PA
    Posts
    1,017
    subbin
  11. #11
    Join Date
    May 2011
    Location
    Munroe Falls, OH
    Posts
    1,841
    Quote Originally Posted by malaki View Post
    http://m971.photobucket.com/albums/X...f5l0E%2F3yw%3D
  12. #12
    Registered Abuser oaklandopen's Avatar
    Join Date
    Mar 2008
    Location
    newark, de
    Posts
    3,647
    Utututjgjtjyreytetfjfuerwrjhibjcyc
  13. #13
    Registered Member sderrickson's Avatar
    2002 protege es
    Join Date
    May 2010
    Location
    Wilmington, MA
    Posts
    160
    Subbbbbbbbb
    You sticking with the blue for the bar and wheels?
    Blue '03 protege lx RIP 10/17/10
    Silver '02 protege es
  14. #14
    Awesome User bullshark524's Avatar
    2000 mazda protege es soon to be 2000 mazda protege klze
    Join Date
    Jan 2010
    Location
    Long Island, NY
    Posts
    165
    subbin
    Legendary Build Link>
  15. #15
    Registered Zombie fishdonotbounce's Avatar
    08.5 CWP Speed3
    Join Date
    Feb 2006
    Location
    Wickliffe, OH
    Posts
    6,271
    Definitely subbing. Hopefully I can see this thing in person sometime.
    Past: 2002 Turbo'd Automatic Protege5
    Current: 2008.5 CWP MS3 with a few mods - Build Thread
Similar Threads
  1. Another build thread...OMG!!
    By FunkyBuddha in forum Mazdaspeed Protege
    Last Post: 12-18-2014, 02:23 PM
  2. JDM-P5's Build Thread
    By JDM-P5 in forum Mazdaspeed6
    Last Post: 04-30-2013, 09:21 PM
  3. Cym Re-Build Thread
    By IbanezFreak87 in forum Rotary Mazdas
    Last Post: 08-31-2011, 10:50 PM
  4. My build thread
    By CulRidr in forum Mazda MP3
    Last Post: 05-29-2009, 04:40 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
